Today I was unfortunate Enough to be caught out in that crazy storm and flash floods, and I assuming quite a few other members would have been to. I was in one of the Areas that was Copped it the worst, that being Highhett/Clayton. Now I just wanted to know how bad it is to be driving in flood water thats almost up to bonnet when u have a turbo car? I would have taken loads into the Intercooler, which i imagine couldnt be healthy for the car. after the rain cleared and i was on open road, I noticed the car blurting and jerking when i stomped it in second gear. should i get this checked out immediatly or just chill?
P.S Missing.. a front wheel arch guard, last seen floating down Nepean Hwy. PM if found.
Edited by Gazzilla
https://www.sau.com.au/forums/topic/198471-using-your-car-as-a-boat/
Why would it have taken water into the cooler? They are sealed dude...
Air-to-air coolers use air to cool the air INSIDE. Therefore sealed :whistling:
If the piping wasnt sealed, you'd have a leak and boost drop issues, and notice it long before it filled with water in everyday life.
know what shits me the most ever?
those people that have a sticker/spare tyre cover that says "my other car is a boat"
a car is not a boat. a boat is a boat. a car is a car.
lol.... the 49% bitch 51% angel, dont push me stickers annoy me more
Edited by NORBY
have you got any sort of cold air intake that could have sucked the water up?
speaking of which...how likely is it that your pod would suck in water if you've got a cold air intake pipe running up to the hole where the factory 'cold' cooler pipe would usually be?
after driving in some heavy rain lately, i had a look and found a small amount of water pooled up in that area. i didnt think it would actually get sucked up into the pod, its a good few inches away.
+1 on pod suckin up water if you have one. check you coils and electrics. see how the car runs the next couple days.
a couple years ago i drove through a flooded patch at the glen on springy rd in the parents new corolla. blind leading the blind..ha thought id be right untill the water started going over the bonnet..ha. water got into the headlights...there was some wierd corossive looking foamy pink stuff surrounding the coolant/radiator. will never ever drive through a flooded patch of road again even though others will.
Unless you had a prior leak somewhere else the only place i can think you'd get water is through the pod.
Similar thing happened to me with the Commodore a while back (spluttering and coughing), just drove it easy for a bit and the water will work its way through....
The only other thing could be some sort of elec damage....
I drove home in the worst of it ystrday in the aaah, love the traction BUT, the windscreen wipers are too damn slow, couldnt see shit, ima have to put some new motors in or something, these suck ass!
Also wish i had taken the rolla in, that thing loooves the puddles (well.. i make it love them)
Edited by GTAAAH
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
