Hey Fellas,
Got my new engine put in this week, and after a bit of driving around etc i've noticed that sometimes when the revs are low and building up to boost
at about 2500rpm the car stutters a bit and feels like its holding back, then once it gets past there it boogies.
Now im not sure what this could be, ive narrowed it down to a few things
Vaccum Lines
Dirty AFM as the old engine blew up and oil went everywhere
Any help would be good as my mechanic has just closed down for xmas and i was hoping to get it sorted sooner rather than later.
Any help would be sweet
Also is it normal for the engine to be a bit noisy for a bit after putting it in? It had been sitting around for about 1-2 months before it was fired up and the tappets are a touch noisy, but are quieting down after a few drives.
Trent
https://www.sau.com.au/forums/topic/198497-car-stuttering-before-boost/
My car's done exactly the same thing since I bought it. Bet you're running higher than stock 7psi no? :P Seems like on stock boost there's no problem, at 12psi there's a small cough, and 15psi a big one. Mechanic had no idea what it was.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
