Hey guys,
Replaced my stuffed original castor bushes with whiteline items about 8 months ago hoping they'd be a nice replacement, instead they're very harsh and send vibrations through the steering wheel so I want just get it back to the standard feel.
Does anyone know where to get standard rubber bushes? I think I saw a trader or eBay was selling them at some stage but can't seem to find them now.
Cheers.
https://www.sau.com.au/forums/topic/198510-rubber-castor-bushes-not-urethane/
Hey guys,
Cheers.
That is not at all normal, are you sure it's the bushes?
Cheers
Gary
Yep, bushes were the only things I changed at that time and thats when I noticed it. Think it's mainly due to all the rubbish roads around me, when I'm driving on decent roads it's fine. I didn't really elaborate well in my first post, it's not constantly vibrating it's more of a jolt when when I hit a rough piece of road etc.
Normally when you add caster, you find that the bump impact is somewhat reduced as the shocks are inclinded forward (at the wheel). Perhaps it's the alignment rather than the bushes themselves.
Cheers
Gary
Agreed. There was not noticable increase in harshness from going to aftermarket bushes on any car I've done it to.
Get it to a suspension place, up on the hoist and checked out. Pretty sure you will find something else wrong
I quite like the feel urethane bushes up front and urethane subframe bushes have given the car.
Its a nice solid, sharp, direct sporty feel. Just like a sport car should. Not boaty with no feedback. :(
Maybe I'm not one to comment as I love the harsh motor thump feel of the old camy v8 SLR's and old school fords. Nothing quite like the rawness. (even though they are generally slow) :banana:
Cheers
Gary
Could be an alignment issue, after all I did put them in myself. I'll have to read into it a bit more.
Anyways, probably won't buy them now but these are the bushes I meant here They don't look too bad for the price.
is it just bumpy or you getting bump steer...?
I've put project d castor bushes in they are fine and another r33 put in whiteline adjustables with +1 on them just made steering slightly very slightly heavier...
I get a bit of bump steer but it feels totally different. I'm going to raise my suspension to the recommended settings and adjust the castor to see if this fixes the issue. Now if it would only stop raining :banana:
I'm actually after the stock rubber bushes that go into the front uprights, my whiteline stuff has started squeeking/making noise when cold, very annoying. I've been told its a pain to change them back, nissan don't sell the bushes by themselves you have to buy the whole upright.
Why not grease the bushes, it's a simple job. Take off wheel, loosen one bolt, squeeze grease, do up bolt, put wheel back on, move to other side, repeat process.
Cheers
Gary
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
