Hi Guys,
Just after some info.
Had my series 1 r33 gtst in for a safc2 fitting and dyno car has been a bit shaky sitting at 100 km/h so asked them to do a wheel balance as well. They charged me $120 for wheel balance am i being unrealistic or is $120 for wheel balance way over the top?
Also the balance hasnt fixed the vibrations at 100 seems fine at other speeds just vibrates around 100 any ideas on problem?
https://www.sau.com.au/forums/topic/198535-wheel-balance/
if you have already paid for the service then i think its too late. did the tuner balance your tyre? probably not rocket science by i would have left it to the pro tyre places to do it so you can bring it back for them to adjust again seeing as it wasnt fixed in the first place. the vibration might not even be tyre related.
https://www.sau.com.au/forums/topic/198535-wheel-balance/#findComment-3545002
definate rip off. $10 per wheel is the norm these days, maybe $15 at some expensive place. But id say the tune place would pay that cost, then charge you a little extra so they make money out of it, but $120 is just robbery.
chould you have a flat spot on your tyre? or scolloped inner edges (but that would also be noisey)? or a buckled rim? No balancing will get rid of that?
https://www.sau.com.au/forums/topic/198535-wheel-balance/#findComment-3547056
you are paying to have the workshop remove the wheels and send them off to the tyre place, then paying for the balance, then paying the workshop to pick up and reinstall. remove and reinstall of wheels would be about 30 minutes, plus say 10minutes each way for the tyres to be dropped off and picked up.
So an hour of workshop labour time plus a balance. It's reasonable.
https://www.sau.com.au/forums/topic/198535-wheel-balance/#findComment-3547412
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
