hey guys i reccently had my rb25 tuned, the problem is the car only made 192rwkw on 12psi, even though when i load it up it stays at 10psi, ive seen many std rb25's make this with std ecu etc and now im questioning the tune,the car had some high knock readings under light throttle uphill say 3000rpm not giving it a hard time. to the point where they had to pull timming out from below std settings. this also didnt make much sense.. mods are:
rb25det
std turbo,injectors,afm
greedy plenum
front mount
3inch exhaust
600x300 cooler
fuel pump
powerfc
boost controller is profec B 2...
i wouldve assumed an easy 200rwkw should be in order, the motor is very healthy with good compresion and lil to no leak down...am i expecting to much from these mods? whats your thoughts?
dyno sheet
http://img297.imageshack.us/img297/1940/dsc04149lg3.jpg
Edited by dead32
https://www.sau.com.au/forums/topic/198623-down-on-power/
yea thats what i was thinking, realistic dyno. only problem is it doesnt feel all that well on the street. unless i was just expecting to much,i just cant understand why they had to pull the timming out "less then std" in some load points around 3000rpm. it makes for a very "doughy" pick up if you catch my drift.
https://www.sau.com.au/forums/topic/198623-down-on-power/#findComment-3545944
Ryan,
My RB25 was 195rwkw with same mods minus the plenum.
Maybe go to another dyno tuner for a comparison run?
Or, with my tuner, he says if Im not happy, bring it back and they'll fix it!
Give the person who tuned your car a call and have a chat and tell them your thoughts etc!
Cheers,
Chris
https://www.sau.com.au/forums/topic/198623-down-on-power/#findComment-3545956
Ryan, feel free to pm me if you like :banana:
I know the ceffie was quick without those mods (Ando beat me by .6 of a second!!! :( ) so take it to the track and open her up, see how she feels!
https://www.sau.com.au/forums/topic/198623-down-on-power/#findComment-3545963
The only way your going to improve this figure is with an adj. exhaust cam pulley so you can get some timing into it [then you can pull it back/trim it to suit]. Then I'm only thinking around 200 -210, so you might make a slight diff, but if you have plans to go bigger turbo and cams etc I wouldn't waste my $$$ on a cam wheel.
https://www.sau.com.au/forums/topic/198623-down-on-power/#findComment-3545994
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
