i drive a wine red s1 r33
i have seen a couple of these in a candy apple red and was wondering weather this is a cutom pain job as in sand back and start again or if there is like a... tinted overlay paint you can put on to get these kind of results?
i know its a lame picture but i was serching for the color in google images and that was the closest i could find
Edited by r33rckt
https://www.sau.com.au/forums/topic/198639-candy-apple-red/
Firstly, yep, candy reds are a tops colour, especially if they have a nice flake to them.
But... candies are'nt the easiest or cheapest thing to get & is definatley a custom job. Also very hard to repair if you ever have a smash...
Basically, a Candy is an effect that you get when you spray a base colour down, usually a silver, first. Then apply coats of a transparent colour, like red, over the top, followed by the clear top coats.
Because the candy is so transparent (looks like cordial) the end colour is effected by the colour of the base you use & how many coats of the candy colour you put on, so say 5 coats will be a lighter shade, but 8 would be deeper.
If you all ready have a red car, the only advantage would be that you might not be too worried about all your closed edges, engine bay etc. You wouldnt really have to strip it back to bare metal, as long as the paint is ok.
https://www.sau.com.au/forums/topic/198639-candy-apple-red/#findComment-3546169
LOL theres millions of kandy colours red, green, blue, yellow, lime, teal, purple, violet, magenta
please for the love of god don't use any other kandy apart form House of kolor
i think i can claim the title of first kandy red skyline in oz :thumbsup:
https://www.sau.com.au/forums/topic/198639-candy-apple-red/#findComment-3546857
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
