simple question...
have you had work done / car tuned by either of these workshops?
-- APC (Advanced Performance Centre) - Underwood
-- Millennium Motorsports - Tingalpa
-- Brisbane Tuning & Dyno Centre - Gabba
good and bad comments welcome, but send a PM if you need to cut loose :thumbsup:
https://www.sau.com.au/forums/topic/198678-had-your-car-tuned-by-these-guys/
Brisbane Tunning - yes i have both my R33 GTST and my 34 GTT , they are great for BASIC tune and service .. Turbo overhauls etc as they are HKS and Garett Autherised etc... service wise i wouldnt let anyone else apart from John do the Dyno runs .. as he knows his RB's if your looking at computer tunes etc.. id recommend Godzilla .. had my apexi tuned at Brisbane Turbo .. had a leaner tune to it .. now the car runs better more power at lower boost , mark knows his computer things and engines more then what john would...equally they are both great workshops both are resonable prized ..150 for a one hour dyno tune @ brisbane Turbo , Godzilla 200 a hour tune .. most time you only need hour and a half at the most ..
APC - My brother took his Evo9 tuned there for the reflash .. they are good for small jobs as well but be warned VERY Expensive !.. personally my experiance with them were nothing interesting ..with my RVR they did a crappy job on exhaust and intake install.. which was fixed with a few phone calls to nick .. so i cant really comment if they are good or bad .. average more for your evo fan i guess..
General Service Maintenance id go either Centrax or Sunnybank Signature Service great prices great service !
Edited by 53XYN
me and the wife had a run in with john at btt
it was enough for us never to go back, appart form the work they did was expensive and i had to get some of it fixed at motsons
i wouldnt go there
thanks again,
the reason behind my question... these 3 shops are Greddy/Trust dealers.
As some of you know, I've recently purchased an emanage Ultimate.
was thinking to get it installed by a dealer, as the 'safer' option (internal support from dealer to greddy, etc).
I'm in Sydney Jan/Feb, getting Croydon to do it is the other option.
thanks again,
if u have the opportunity of getting crd to do it, then by all means do what ever u can to make that happen!
I have been to BTT once and Im never going back. They have a downhill dyno (reads way to high) and i was not impressed with prices and the work they carried out on my car...
I would go to Matty Spry at P.I.T.S down the coast for a tune, he has been tuning my cars for about 4-5 years and has never given me a reason to go anywhere else..
Sorry to intrude on your thread Chris, but I think everyones missing the point.
He is not asking for alternative workshops, he wants to compair the "Greddy" authorised workshops around.
No doubt Matt is a great tuner I agree however he does not work with Greddy Ecu's at all.
1+ for matt at P.I.T.S plus he can have access to GREDDY direct support also... plus he knows most systems like the back of his hand anyways... he's been doin my car ever since the rebuild and he has given me no reason to look elsewhere
He might be able to gain access to dealer support like anyone who sells the product but he still does not work with the units, he said so himself.
Ill be the first to plug his work too if he was a suitable choice ---> http://www.skylinesaustralia.com/forums/Da...y+day+with+matt
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
