Make: Nissan
Model: 300c
Milage: 280XXX
Transmission: Auto
Colour: Grey over Silver
Complied? Yes
RWC supplied? Depending on sale price
Currently registered? Yes
Price: $7500 OBO
Contact: Scott - 0421 973 558
Comments / Modifications:
Awesome Cruiser!
This is a fantastic car that turns a lot of Heads!! Nobody seems to know what it is!
It is in awesome condition for the age! She?s 22 years old and only has a few little taps here and there. This is a very reliable car and I have not had to spend much on it to keep it running great. Parts are easy to come by, as Nissan likes to have the same parts fit many cars.
Recent Major service completed, including a new battery being fitted.
She was on display at the 2007 Melbourne Grand Prix, as well as Melbourne Autosalon with Skylines Australia.
Driveline.
Imported VG30E (3ltr V6) twin throttle body engine and auto gearbox from Nissan Cima.
Pod filter.
2.5" exhaust from headers. 1 resonator and 1 semi straight through muffler with twin tips. (Very, very quite system).
Interior.
Perfect dash - no cracks.
Plush velour seats.
Wood grain inserts ? Extra woodgrain imported from Japan.
Rear courtesy lights with ashtray spotlights.
Sound deadening in all doors and boot.
Eclipse CD head unit.
PPI front 6" splits in custom door pods (not connected).
PPI Carbon series 6x9 in custom ported rear parcel shelf.
Darkest legal tint on windows.
Retrimmed boot.
Exterior.
Brownish Grey over Silver.
Polished chrome highlights.
Polished front grill.
Glowing front guard corner markers imported from Japan.
Removed badging.
Suspension and wheels.
Custom built Pedders front struts.
Pedders lowest front spring to suit 1984 300ZX.
Pedders Short throw rear shocks to suit Commodore ute modified to fit.
Pedders Lowest rear spring to suit commodore.
18 inch Lenso Widetracks, with new tyres.
Many spare parts including:
Imported Japanese Brougham tail lights and garnish.
Original dash inserts.
Interior trim pieces.
Extra Badges.
Main engine fuses.
Air box.
Front lower lip.
Extra springs.
Tinted front indicators (as in photos).
The car comes with some service history.
All questions and inspection welcome.
Images:
https://www.sau.com.au/forums/topic/198692-nissan-300c/
I have seen this car in real life and its really quiet nice.
Its something different, original and would make a great cruiser for anyone.
At $5,500 you can't go wrong!
Good luck with the sale Scott.
Abu
https://www.sau.com.au/forums/topic/198692-nissan-300c/#findComment-3570802
  • 2 months later...
looks unreal mate.
ive got a friend at cit who is looking into oldschool bmw's at the moment, i might get him onto this i dare say he would be interested.
may i ask what rwkw figures you were making with the vg30e?
https://www.sau.com.au/forums/topic/198692-nissan-300c/#findComment-3768786
  • 7 months later...
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
