I wrote this up to hopefully stop the innundation of many threads asking the same question. What bulb for what car? (sticky maybe?)
I don't have all the information, so if you have some information on the other types of cars, please PM me with the information and I will add it :rofl: (31, 32, 34 and V35 Skylines)
---R33 Skyline---
All 4 headlights are H1, the reflectors in the headlight spread the light differently between high and low beam
The driving/fog lights are H3
The parker lights are regular wedge type parker lights, sometimes known as E1.
The brake lights are regular bulbs (type 1157) with the two prongs on the bottom.
The blinkers and reverse lights are regular bulbs (type 1156) with one prong on the bottom.
https://www.sau.com.au/forums/topic/198713-skyline-bulb-types/
You have to turn them 90 degrees...
To get the drivers side one out, I suggest you take out the washer bottle and undo then move the fuse box back...
It's still pretty crap though, but it males it a whole lot easier...
To remove the parkers on the drivers you need to remove the washer bottles and the fuse box cover, that should give you just enough room. They need a 45deg turn and then they pull out, but they are tough little fûckers... Try the passenger side ones first to see how they come out...
T5 for parker? I always thought it was T10?
I thought it was T5 because I pulled out my T5s from the dash and put it in the parkers.. that's what i'm running in there at the moment, same lights as my dash ones. Perhaps they're socket compatible?
hay ive got a 1994 s1 skyline with the fog lights and indecators in the front bar, but ive got no button for the fog lights and i dont even know if there is any in there haha. just wondering if i was to put some h3 lights in there where could i wire them up to or where are they supposed to be wired up to????
There should be a little thing on the indicator stalk that you twist to turn them on...
Legally, I am pretty sure they are supposed to be on a seperate circuit, and even more legally, you can only use them in foggy conditions... not doing so will result in a fine...
HOWEVER, I do remember hearing about people not having bulbs in there at all... like, not even the holder or the wiring, just the glass basically... kinda odd :D
I got a set of strobe lights in my foggies hehe
I dunno about R34s but the R33 parkers, rear number plate lights and dash dial lights are all T10s
Also foggies are T10 and the front indicators are interchangeable with T10s as well.
Edited by POLICE
HOWEVER, I do remember hearing about people not having bulbs in there at all... like, not even the holder or the wiring, just the glass basically... kinda odd :(
my m8 has a s2 and his has that twist thing on his but mine doesn't have it at all, i have the holders but no lights or wires in it. what else can i wire some up to???
You could wire them up to the regular lights, but this would take a lot of work, and again, you would proably get in trouble for it...
The best idea is to just make your own switch for them... though you have to remember that if you get a different front bar, or a large front mount intercooler, all this time will be wasted anyway...
A very useful write up... thanks mate... yeah, I think sticky this one.
I have it bookmarked for now, hopefully when I do the other types of skylines, it will get stickied :P
Thanks mate.... very very helpful
Thanks :P
Can't wait to steal some time with mates cars to check the other types though :(
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
