Hi guys,
Sorry I'm not too savvy with electrics but can I confirm that in an R34 GTT:
a) "parkers" are the lights on the outer most side of the headlamps? From outside to inside: parkers > low beam > high beam?
b) The parkers bulb is a T10?
c) If you have HID installed for the low beam(H1), do you need another set of kit with additional ballast for the parkers or do you just need the extra HID bulbs and plug it into the existing low beam ballast?
Would greatly appreciate any advice on this!!
Cheers. :)
  • 3 weeks later...
Could I suggest including wattage information?
I can confirm that an R33 GTST takes 55 watt H1's in the headlights.
I suspect that going higher *might* do some damage to the plastic lenses? The Philips globes I bought (55w Crystalvision 4300K) said something about being UV coated so that they're safe to use with plastic headlights.
The s2 foglights also use 55w globes, in H3. I was *almost* about to buy some "JAG" branded 100w H3's, but i'll probably play the safety card and try to find 55w globes instead. The foglight assembly is metal, and the lens is glass, so it probably would take 100w anyway.
-Steve
  • 5 months later...
Will post this up cos its not all that easy to find -
R34 GTT Tail light bulbs -
Outside (larger) tail lights - 1 x T20 Dual filament bulb. Wedge type (if you dont get the dual filament, it will only light up when brakes are applied, not when headlights are on)
Inside (smaller) tail lights - 2 x T10 wedge type
  • Like 1
  • 7 months later...
  • 6 months later...
Hey guys my headlight just went and I was thinking of getting some 100w h1 bulbs to replace both headlights I don't really care about high beam as the 100w will be enought for all kinds of driving I just wanted to know if it will stuff up my headlight like the plastic and how clear they are
  • 1 year later...
anyone know what the globe is called.
The one on the roof at the front (near the sunroof buttons), im missing the globe but the power of the globe is 12v 10w is it states.
what kind goes in there? :/
tiny screw in?
Edited by Skyline_034
  On 15/07/2011 at 5:17 PM, corpse. said:
wait so r33's take 4 globes aswell as the 2 parkers? 2 low beam and 2 high beam?
(im use to commodores with H4 globes)
Yes this is right, they use 2 seperate lights, 1 for each. Alot of commodores use 2 bulbs the only difference is that they use a H4 which does low and high beam then they have another bulb just for high beam.
Park lights are the same deal, Usually Wedge (T10) bulbs in alot of different cars
tiny screw in?
Use this to work out which one it is. I replaced mine with LED's (can buy them from supercheap) that have 4,6,8 etc LED's and then have attatchments that plug/screw into your existing socket
http://www.narva.com.au/products/browse/instrumentlicence-plate
    • Took it to all Japan day, flogged the hell out of it and took it all, am a very very happy man  don’t know how that ended up in Greg’s thread before
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
