Hi all.
Went out for dinner tonight turned the car off, went in had dinner, came back out and car wouldn't start, headlights and brakelights etc are working but the ignition wouldn't come onto reds and the car wouldnt crank. Anyway I got pissed off with it and went and had a drink to cool down, when I came back it miracously started.
Got it home fine, turned it off and same thing again just refuses to start no red ignition lights nothing, called NRMA, they came out checked all the fuses and relays and said everything was fine and other then that they had no suggestions on what to do :rofl: The battery is new so its not that, anyone have any idea what this could be? I only got my licence back on Thursday from a 6 month suspension and since then I havent even been able to have a proper drive of it as it blew a clutch hydraulic line on Thursday, got that fixed now this problem.
https://www.sau.com.au/forums/topic/198737-r32-wont-start/
Does the car have an alarm? How long had the car been sitting around (while you were on "no licence")? It could be the alarm has died, and is intermittently activating the immobiliser function.
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3547436
Same as my problem. http://www.skylinesaustralia.com/forums/He...33-t198464.html .Mine cranks though but doesnt start.
Its done it once with me but seems to be working ok now. Im still gonna go to an auto electrician though.
Edited by NRV155
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3547908
Was playing around with it more today and I had the key in the position where it would normally be on reds and nothing was happening, but when I turned my headlights on the reds would come on and I was able to start the car, it done this about 5 times in a row until it stopped working altogether again, so I guess I have some weird crazy wiring issue.
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3547990
Damn dude this sucks I rang a few places today and no one could come look at it, is their anyone on here thats an auto leccy that could come look at my car in Sydney tonight? If not does anyone on here know any good mobile auto electricans that service the Sydney area and are familar with R32's, I really want to get the car back on the road ASAP.
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3549247
  jap VL R32 said:
hi my r32 wont start when its cold but if i have driven it it will start first time fine
Yours is a different problem to ours.
Dave, if you find out the problem before me, post back here and let me know what it was and how it was solved. :)
Shit thing is that no one is open for the next couple of days and mobile electricians may charge a small fortune for public holiday service unless you can catch someone tonight.
Edited by NRV155
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3549294
Yer mate im going out to the car now to have a good hard look at everything pull the dash apart etc, so wish me luck and if you find out your problem be sure to let me know.
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3549303
Ok well I took as much of the dash and ignition apart as I could and traced back all wires to check their connections etc, couldnt find any problems, disconnected the alarm and immobiliser still wouldnt start, removed my HID install thought that might be conflicting with something, still didnt fix it. So looks like no car over Christmas / New Year for me ;) oh well thats life
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3549566
  NRV155 said:
Just got mine done too. Seems it was faulty/loose wires in the turbo timer harness. Just removed it and seems to be fine now.
If You've Got A Blackwidow Immobiliser It Could Be That Too My R33 Gtst Is The Same... No Regs But Only Happen When i Push The Immobiliser Button, It Seems To Cut the Battery Out But theres Power Everywhere ;)
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3573628
  • 1 month later...
i had the same problem on my r32 gtst, its the starter motor. because its expensive you get a mitsubishi lancer starter motor and replace the big black cylinder, not the small one and there are 4 screws you to undo and wen u open it if its black inside then change change it with the big black lancer starter, and put it back on, i wish i took some pictures because i did this about a month ago and the car starts even better than wen i first bought the car, if u know how to do it, get an electrician and he will do it for 20 bucks. ==IMPORTANT BEFORE YOU DO ANY THING YOU HAVE TO TEST THE FAULTY STARTER AND SEE WHICH WAY IT ROOLS MINE WAS ROLLING TO THE LEFT, AND THEN PUT THE LANCER ONE ONE AND TEST AGAIN IF IT ROLLS TO THE LEFT IT WORKS==
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3695643
Doesn't work with mine... definetly the immobiliser... doesn't work even when on anymore! you should see the security measures i go to now... 3 pittbulls 2 club locks and a mother in law as a last resort
https://www.sau.com.au/forums/topic/198737-r32-wont-start/#findComment-3696921
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
