Which silicone do I use to put on my coil packs to help the missfire on boost? There's a lot of different kinds, like the gasket stuff and the spray silicone, but can someone give me a picture or the name brand and which type of which one to use please? Also, is silicone the best thing to use, because I have seen posts about people using clean nail polish and heatwrap and stuff. I HAVE SEARCHED TOO!
Thanks,
Mike
Edited by Michaelove
https://www.sau.com.au/forums/topic/198765-about-siliconing-your-coil-packs/
Selleys 401 is the one i used. Its industrial grade high temp silicone, used as an insulator, amongst other things. You can get it at bunnings.
It's probably just as important to clean the contacts on your coils, where the spring sits.
The last thing i tried was stretching each spring about 8mm longer, to make a better connection with the spark plug. I havent had a misfire since, but then the weather hasnt been freezing cold, so it may be due to that.
Edited by Munkyb0y
Thanks a lot.
no that wont work. that's more like a lubricant. get the 401. it's only $10.
Okay, the problem is that I live in USA and we don't have bunnings. Do you know of any other brands? Or any other stores I Can get it at? I don't think USA has shellys
what is the silicone supposed to be used for? ie, painting, flooring, ect? Is it like the caulking stuff?
it's used to seal glass on oven doors, and also used as an industrial electrical insulator.
not sure of an equivalent product, but there would be something.
here's the selleys 401. it's the only pic i could find
sweet! thank's a lot man. one more question! where exactly do i put the silicone on the coil packs? that's the last thing i can't find =/
here are mine
seal the whole underside of the coil, up to the bracket. leave the stem uncoated, as you need to fit the rubber boot over that. also make sure you clean those contacts. u can see mine are shiny gold. they were a dull grey when i started.
here are mine
awesome. thank's a lot.
no worries man.
have you made sure your missfire isnt caused by your spark plugs? 0.8mm gap is highly recommended, although nissan specify 1.1mm
and many people have found the copper plugs to be better than the platinums/iridiums, that are also recommended.
Edited by Munkyb0y
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
