  • Replies 51
hey all, new to the world of jap cars :banana: is this drift prac for everyone or only for the experienced peeps ??? always wanted to give it a go in a controlled environment (basically somewhere where there aint much to hit hehehe) let me know the details cheers guys
lol one day hey flick :(
cost is $10 at the gate, another $80 for the drifting and if you dont have a CAMS licence another $20 for a day licence. Then petrol, tyres etc.
Good on ya as others said for wanting to give it a crack out on the track, too many ppl try and do it on the street and end up damaging or writing off their cars completely, very few accidents happen on track.
Now now young lady. Don't let that stop you.
Cost will be around the $3 - 500 mark.
After fee's for drifitng ( entry, track fees, cams licence), fuel, tyres, helmet, long sleves.
Good luck with getting ya 4 whore sidewayz and enjoy yaself.
OH and by the way do not be ashamed to ask for the person behind you to be let off later.
I always do it and it gives u that bit more confidence of not having to worry about someone being held up because you spin or are slow.
Good luck mate.
Oh and i will be out there but not sliding.
My car will be out of action as new parts will be on in a week and that week is drift prac week.
Toodle PIP
depends, ull spend a touch over $100 to get through the gates and on the track, then depending on what u use, $50 - $100 for tyres and fitting (i can help u out if ur running 17's), have a full tank when u get out there, ull use most of it, borrow a helmet, make sure u have long sleeves. shouldnt spend more than $300. i rarely spend over $200 for a day.
cheers for that guys, might hafta get some funds together.... only thing i have to ask is what kinda long sleeves they talkin about ???? i have a helmet coz of my motorbike thats sorted... so all i need is some crappy wheels and tyres, i think my tyres will be too big lmao dang 265s on the back hehehe so if anyone has a cheap set of r33 rims and tyres i can buy id be keen to know how much id be up for :)
cmon flick auto or not u still have N and D hehe :banana: and of course your handbrake :down:
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
