I am unable to figure out which wire makes the automatic aerial go up.
The standard nissan wiring diagram didnt even match the wires shown in my car
Does anyone know which wire should be the aerial in the a cefiro would be good if somone could tell me
Regards,
Stephen
ahhh i only put in my stereo a little while ago an dont quite remember which wire it is but i do no that mine works but doesnt go down wen i play cds or my ipod through it, if i get sum time ill have a look to c which wire it is
That was the same as me, until a few days ago.. Now it wont go down at all, hear the motor trying to retract it, but nothing happens. Ive been wanting to lower it so it doesnt come up at all, just looks so damn wierd. :)
do you still have the factory plugs on yours?
if so:
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
and yours is the top one. the colours may not match but the pinning WILL.
If you do manage to lower it, you can unplug the loom to the motor in the boot so that it won't try to go up/down when the radio turns on.
That was my plan... when I decided I would do it, mine stopped going down altogether. :D
That was my plan... when I decided I would do it, mine stopped going down altogether. :P
Seeing how you are using my thread for other aerial issues :D
go into your cefiro
Remove gearbox console
Unscrew the 6 screws
remove deck
Check wire to aerial
then tell me which one :woot:
regards,
Stephen
Yo, I took had a look at mine today, my head unit only has 1 output for aerial and amplifier, so mine goes up as soon as the headunit turns on regardless if I'm listening to CD or some other auxillary unit, just in case anyone was wondering why theirs doesn't wind down until they turn car off.
The blue wire is the output from the headunit which I have spliced into the factory loom. The wire in question is circled in red in the photo, it's colour is black with a yellow stripe and grey bands. This wire follows through the car to the loom plug at the aerial in the boot, there you can see I've spliced another wire in there to turn my amplifier on too.
Also, while I had my head unit out I decided it would be a good time to tackle the problem of my coin/cup tray not retracting. Some coins had fallen down behind it and were blocking it from closing properly. So I pulled it apart and opened it up and guess what I found.... [/pause for suspense]
I thought I was going to need adaptor then I had a closer look and there are two aerial plugs lying around behind the headunit. Whether yours is the same though....
100yen is nothing, when I first bought the car there was $20 (australian) behind the middle seat where it folds down.
My mate found 5 yen in his skyline, I pity him.
Edited by daisu
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
