Hi guys and girls,
last week when i went for a weekend cruz i pulled out my driveway and herd a creaking noise coming from the front rhs but it only happens when the shock it under pressure i got tein coilovers on the car and was wondering if they gotta be topped up with oil/grease at any time, if anyone has had a similar problem would you be able to tell me what you`ve done to fix it, im not to sure if its the shock or steering arms etc.... you help and advise would be great
Cheers
https://www.sau.com.au/forums/topic/198827-creaking-from-front-rhs/
Chances are its one or mmany of ur wishbone/control arm bushes. They get old and begin to creek as there is not enough lube in the bush or they have just gotten so old that they have perished. If they are aftermarket nolathane type bushes in there then it will be caused from lack of lube (i highly doubt aftermarket ones would have perished already). On my whiteline ones, there is a grease nipple where u can put a grease gun on and lube them up, but this may not be the case in your situation. If so then it looks like u will have to remove the bushes and relube them.
Good luck
David
Edited by R32Abuser
ive had all new bushes put on around 2 months ago, but i pulled the wheel off and chucked a grease gun on the grease nipple and gave it a squirt but havent been able to check if its fixed cos am waiting on a few bit before i can take car out, but when i jacked it up it creaked and when i put it down it didnt so then i jacked it up again and it didnt creak so hopefully it just needed a grease
could be your shocky, mine has a slight creeking noise when jacked up and lowered.
jack it up and just check if its leaking anything, or leaving a greasy residue, you might have to take the wheel off for a descent inspection.
if your real worried about it pedders do a 32 point steering and suspension safety check for only $16. could be the best thing for you to do. then that will tell you if there is anything wrong or anything that could go wrong.
cheers 4drftn
are those tests just a waste of time?? and they'll tell you you need a million things done to the car?
i've heard nothing but the absolute worst things about pedders, and even seen websites previous franchise owners have started to share the word on how crap a place pedders is, so i've been put off from anything pedders since then. But a 32 point inspection for $16 sounds good in theory....
I don't think they are a waste of time, though in all honesty if you had half a clue you could do one yourself and save 16 bucks.
Is the creak from the suspension or is it the body creaking as you load up one side?
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
