Hi guys and girls,
last week when i went for a weekend cruz i pulled out my driveway and herd a creaking noise coming from the front rhs but it only happens when the shock it under pressure i got tein coilovers on the car and was wondering if they gotta be topped up with oil/grease at any time, if anyone has had a similar problem would you be able to tell me what you`ve done to fix it, im not to sure if its the shock or steering arms etc.... you help and advise would be great
Cheers
https://www.sau.com.au/forums/topic/198827-creaking-from-front-rhs/
Chances are its one or mmany of ur wishbone/control arm bushes. They get old and begin to creek as there is not enough lube in the bush or they have just gotten so old that they have perished. If they are aftermarket nolathane type bushes in there then it will be caused from lack of lube (i highly doubt aftermarket ones would have perished already). On my whiteline ones, there is a grease nipple where u can put a grease gun on and lube them up, but this may not be the case in your situation. If so then it looks like u will have to remove the bushes and relube them.
Good luck
David
Edited by R32Abuser
ive had all new bushes put on around 2 months ago, but i pulled the wheel off and chucked a grease gun on the grease nipple and gave it a squirt but havent been able to check if its fixed cos am waiting on a few bit before i can take car out, but when i jacked it up it creaked and when i put it down it didnt so then i jacked it up again and it didnt creak so hopefully it just needed a grease
could be your shocky, mine has a slight creeking noise when jacked up and lowered.
jack it up and just check if its leaking anything, or leaving a greasy residue, you might have to take the wheel off for a descent inspection.
if your real worried about it pedders do a 32 point steering and suspension safety check for only $16. could be the best thing for you to do. then that will tell you if there is anything wrong or anything that could go wrong.
cheers 4drftn
are those tests just a waste of time?? and they'll tell you you need a million things done to the car?
i've heard nothing but the absolute worst things about pedders, and even seen websites previous franchise owners have started to share the word on how crap a place pedders is, so i've been put off from anything pedders since then. But a 32 point inspection for $16 sounds good in theory....
I don't think they are a waste of time, though in all honesty if you had half a clue you could do one yourself and save 16 bucks.
Is the creak from the suspension or is it the body creaking as you load up one side?
    • Hi guys my 94 r33 gtst fuel pump has gone out. I have a walbro 525 ready to go in but am unsure if I need to upgrade the fuel tank bulk heads? Ive heard that others have issues with the stock wiring melting... Ive seen alot of people recommend this: https://frenchysperformancegarage.com/products/fpg-nissan-skyline-r33-r34-silvia-s14-s15-billet-fuel-tank-bulkhead-hat-top-an6-with-high-current-connector-apex-2-8-delphi-fpg-100?variant=42873255198898 My current pump that stopped working is aftermarket but I had no relay mod or upgraded connectors. Need some advice please. TIA
    • It’s new. It’s the cd009. I did take the transmission apart to mill down the bellhousing and had both housings come off the gears so wondering is something isn’t in right. I am running redline. I can get it in gear running too but it’s just not easier and it’s almost like 2, 4, 6, and reverse all the back gears aren’t happy going in
    • I’ll remember that as a last choice. It’s brand new
    • Got keys and did a walk around the yard planning the landscaping works with the family that I will be doing Main effort: remove all the woodchip in the gardens that are around (attached) to the outside of the house and replace with 10mm blue metal, having woodchip close to the house is a recipe for inviting white ants, currently there are no white ants within the block and I would like to keep it that way I'll be buying some large raised garden beds to grow veggies and stuff, and the woodchip will be mulched with everything else that gets dug up, pulled out, or cut down during works Next will some minor drainage and landscaping maintenance up one side of the house, where the fuse box, AC, and solar stuff will go, about 12 mtrs long by 2 meters wide, I'll break up the soil, add gypsum and then I'll dig in a French drains about 300mm deep x 300mm wide and fill it with agg pipe and blue metal, then level out the whole area with a 50mm layer of blue metal, the soil, whilst currently pretty compacted, will break up well with the gypsum to aid in drainage, I'll then cover the area with a 50mm layer of more blue metal In saying this, the drainage issue is minor, but that little hidden away area down the side is untidy and weedy, and as all of the main elec stuff is there I want it neat and tidy to appease my OCD Again, the material excavated from the French drains with be added to the garden bed mulch, as will some rose bushes and some other crap looking garden plants, and a old apricot tree that is looking worse for wear The apricot tree is currently in a little roundish garden bed that is in the middle of the back yard with few other crappy looking plants around it, that will all be removed, levelled, re-turfed, and is a perfect spot for a hills hoist There is also a area about 3m x 2m between the rear fence and shed that will get some attention, it looks like some stuff was stored there and the grass is dead, that will also get broken up and mulched, and is a prime spot for a pumpkin patch I've guestimated that I'll need: 3 tonnes of blue metal, 12 meters of agg pipe, 5kg of Gypsum, and a hills hoist, so a few bags of concrete as well to set it in place (the house currently has one of those pull out 4 line jobs, whilst it works, I want a retro old school hills hoist), I am also going to run some chickens, there's a great spot for a coop, so a chicken coop to suit 4 of those lovely egg laying bitches will also be on the job card That should keep me busy for a while, and will finish off the back yard ready for a early spring planting of some veggies and berries  Once the main effort is done I'll start out the front, there's a large rock garden that could use some TLC, but that is only minor works Should be fully moved in within 2 weeks, the landscaping works will start then Fun times, retirement is good
    • It happens, that's what your single stage filler is used for.  If it is still visible after the 3 coats of 2k primer, it will be visible after the paint is laid down.  Its hard to give 100% perfect advice without being there in person, I'm very tempted to say stop where you are, fill your pin holes with a single stage putty first then keep going.
