  • Replies 60
well. yes kind of. it depends how tight it is and how tolerant you are of the noise.
basically, if it is tight it will "skip" in tight turns at low speed, eg every time you park in the Woolies car park. Personally it didn't worry me because the on track performance was so good, but mothers with strollers used to look at me like I was the devil
sorry to hi-jack - but whats a good to average 1.5 diff cost these days?
Duncan - dont blame them :happy:
yeah under 20 or even slower. at quicker speeds the wheels can sort themselves out and turns dont tend to be as tight.
yes you can tighten a mechanical diff by adding or changing shim thickness. but aftermarket ones will already be pretty tight
Can you heel and toe?..
I know its quite hard to keep a 1.5 in cheak when you give it a hiding or in the wet and you dont heel and toe down gears.. compression lock up is a biatch..
Do u mean compression lock is a bitch on a 1.5way compared to a viscous diff or compared to a 2way?
If anyone wants a nice quiet streetable diff, go no further than a Nismo GT LSD Pro TT-Model 1.5way. It's the 'softer' model than the rest.
yeah i was looking into the Nismo GT LSD Pro TT-Model 1.5way, would anyone happen to know the life span of these diff before a rebuild is needed???
A lot longer than other diffs. 1) Because as they wear, you can adjust the preload to compensate and 2) they have a lower overall clamping force on the clutches than other diffs.
well looks like the diffs going in
thanks alot guys
cheers
if its a daily driver keep the viscous diff!!!
mine went from daily driver to weekend car as soon as the 1.5 way kaaz went in, but the nismo sounds nice
if i were you, i would take a ride in a car with a mech diff before you decide, its not the skipping thats the problem, its the *CLUNK CLUNK*, very loud!
and then you gotta try and convince everyone that its normal
??? Great back to square one???
thanks for the heads up champ
Any one else like to comment?
Just a couple of quick ones:
i also agree that you don't want a 1.5 way in a daily driver, particularly if you have any sort of subframe bush upgrades, pinapples or alloy collars. I'm sure people do it and are happy to do it but i think thats what pushed mine over the edge as far as being a nice car to drive around in.
Re the nismo wearing less and having adjustable preload. If it slips more (less preload) it wears the plates more. It's not infinitely adjustable either, there are 3 levels of preload so if it wears and you bump up the preload to the next step it's actually a bit of a jump, rather than a tweak. To tweak it you'd need to get it apart.
As an alternative, maybe consider a GTR rear end, they are a mechanical type lsd, 1 way and a bit looser than your average aftermarket diff so much nicer in the day to day grind, or even a torsen out of an s15. both options require a bit of work though and a few more bits swapped
They are a two way, not one way. I used to have a Nismo 1 way and it was very obnoxious. You do get used to it and you learn to drive around it a bit but everyone does look at you funny, which I quite enjoyed. Still, some days, maybe I was a bit tired or cranky, it would annoy me a lot. Now I have a full GTR rear end and it's much nicer on the street. The lock up on the track isn't as good but overall I would say that it's a better compromise for a street car.
To do this you need the diff centre, housing, half shafts, drive shafts and hubs from an R32 GTR. It all bolts up. I got the lot with rear subframe for $700 from a mate. SSS wanted $1200 so somewhere in between there is your window.
That said, I agree that you should get someone who has a 1.5 way or 1 way to take you for a little drive so you can see what it's like. Any old SAU type event should do or post up where you are and maybe someone from here lives nearby.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
