  • Replies 60
well. yes kind of. it depends how tight it is and how tolerant you are of the noise.
basically, if it is tight it will "skip" in tight turns at low speed, eg every time you park in the Woolies car park. Personally it didn't worry me because the on track performance was so good, but mothers with strollers used to look at me like I was the devil
sorry to hi-jack - but whats a good to average 1.5 diff cost these days?
Duncan - dont blame them :happy:
yeah under 20 or even slower. at quicker speeds the wheels can sort themselves out and turns dont tend to be as tight.
yes you can tighten a mechanical diff by adding or changing shim thickness. but aftermarket ones will already be pretty tight
Can you heel and toe?..
I know its quite hard to keep a 1.5 in cheak when you give it a hiding or in the wet and you dont heel and toe down gears.. compression lock up is a biatch..
Do u mean compression lock is a bitch on a 1.5way compared to a viscous diff or compared to a 2way?
If anyone wants a nice quiet streetable diff, go no further than a Nismo GT LSD Pro TT-Model 1.5way. It's the 'softer' model than the rest.
yeah i was looking into the Nismo GT LSD Pro TT-Model 1.5way, would anyone happen to know the life span of these diff before a rebuild is needed???
A lot longer than other diffs. 1) Because as they wear, you can adjust the preload to compensate and 2) they have a lower overall clamping force on the clutches than other diffs.
well looks like the diffs going in
thanks alot guys
cheers
if its a daily driver keep the viscous diff!!!
mine went from daily driver to weekend car as soon as the 1.5 way kaaz went in, but the nismo sounds nice
if i were you, i would take a ride in a car with a mech diff before you decide, its not the skipping thats the problem, its the *CLUNK CLUNK*, very loud!
and then you gotta try and convince everyone that its normal
??? Great back to square one???
thanks for the heads up champ
Any one else like to comment?
Just a couple of quick ones:
i also agree that you don't want a 1.5 way in a daily driver, particularly if you have any sort of subframe bush upgrades, pinapples or alloy collars. I'm sure people do it and are happy to do it but i think thats what pushed mine over the edge as far as being a nice car to drive around in.
Re the nismo wearing less and having adjustable preload. If it slips more (less preload) it wears the plates more. It's not infinitely adjustable either, there are 3 levels of preload so if it wears and you bump up the preload to the next step it's actually a bit of a jump, rather than a tweak. To tweak it you'd need to get it apart.
As an alternative, maybe consider a GTR rear end, they are a mechanical type lsd, 1 way and a bit looser than your average aftermarket diff so much nicer in the day to day grind, or even a torsen out of an s15. both options require a bit of work though and a few more bits swapped
They are a two way, not one way. I used to have a Nismo 1 way and it was very obnoxious. You do get used to it and you learn to drive around it a bit but everyone does look at you funny, which I quite enjoyed. Still, some days, maybe I was a bit tired or cranky, it would annoy me a lot. Now I have a full GTR rear end and it's much nicer on the street. The lock up on the track isn't as good but overall I would say that it's a better compromise for a street car.
To do this you need the diff centre, housing, half shafts, drive shafts and hubs from an R32 GTR. It all bolts up. I got the lot with rear subframe for $700 from a mate. SSS wanted $1200 so somewhere in between there is your window.
That said, I agree that you should get someone who has a 1.5 way or 1 way to take you for a little drive so you can see what it's like. Any old SAU type event should do or post up where you are and maybe someone from here lives nearby.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
