  • Replies 60
My 2way is noisy as hell, mostly when it's cold - it either skips or the clutches chatter away. Once it's nice and warm it's barely noticeable.. might try some new oil..
Oh and it is a bit clunky but I was warned of that.. button clutch + 2way = lots of fun :devil:
Edited by bubba
yeah there is nothing intrinsic about a mechanical diff (1, 1.5 or 2 way) that makes it noisey. Its the "tightness" of the mechanical diff that makes the difference, and the GTR one is pretty loose from the factory. But you can tighten or loosen any mechanical diff.
the only thing that wears out in a viscous diff is the viscous coupling. which is why they start single spinning.
i got a two way n makes a loud chatter at low speeds n skips at higher speeds and holds perfectly wen driftin uphill or track lol
but yeh 2 ways make noise no matter wat but the best thing is they are LEGAL lol
SLY-dN, how are 2-ways legal? I had my viscous diff shimmed up in an attempt to find a compromise between stock and my fully clunky 2way cusco, but the shimmed stocky came back behaving EXACTLY like the cusco 2-way i had in it before!
Anyway, whilst going for inspection they noticed it skipping as the car was manouvered to the pits, and would not clear defect until it was returned stock.
As for noisiness, i think mine must be due to the alloy subframe collars. The clunking was so harsh, as someone mentioned, you have to explain to everyone who rides in the car that its "normal", "no its not broken its meant to be like that"!
Im looking for a diff now. thinking the OS superlock 1.5way. If its clunky ill throw some new stock rubber subframe bushes in. The idea of changing the bushes was to get rid of axle tramp, but with traction it still tramps anyway even with the alloy collars.
Whilst we're here, anyone like to kindly refresh the principle between 1.5 and 2 ways and the pro's cons?
thanks
its not the number of ways that make it "clunk", its the tightness of the diff.
1 way only locks on acceleration, 2 way lock on acceleration and braking, 1.5 way locks on acceleration and a little on braking. How quickly it locks (eg under brakes) is controlled by the ramps in the dif centre. 1 way looks like "|/", 2 way looks like "\/" 1.5 way is in between. In any case they will only lock when there is a change in force ie if you are just coasting no mechanical diff will clunk.
so....if you don't want to get noticed, especially with a 1 way diff, just don't put any power in as you turn, just coast around.
pros and cons....well 1 way is perfect, 2 way have become "trendy" thru fil sic drifters with the theory that the locked diff under brakes on entry make it more predictable. I don't drift so I don't know but that doesn't make sense to me a 1 way is more predictable under brakes because its not locking/unlocking as you have more or less braking.
also a tight diff will increase your understeer out of corners because the inside wheel is forced to turn at the same speed as outside wheel - this makes the car go straight on. Especially bad in a gtr with a tight front diff as well. tight 2 way diff will also increase understeer at initial turn in to the corner
i haven't read the replies, but i know a 32 GT-R with standard LSD oil in it's OEM mechanical 1.5-way diff is fine (but veerrry tail-happy in the wet), but once you change to something like the pink Redline LSD oil, it will start to bite like a mofo in anything resembling low to moderate speed corners
No fun -- could have said your mechanic put the wrong oil in it! I had lightweight shockproof in (communication breakdown) and the diff was so tight the car would actually refuse to move on full lock at low speeds!
I got to agree with the fellas saying the mech diffs with alloly subframe bushes are a bit much for the street. I haven't known any different, but some days especially city driving in traffic its just too much. I want to park it and walk home.
That and I think mine being old, 1 piece tailshaft, big clutch, stiffly sprung just adds to the pain, every little thing just gets transfered. Also I reallly dont like the 2way bit in the wet. I think 1.5 is the good compromise. Just dont have too soild rear end. They will clunk, and they will skip. Thats how they work, the clunk is it locking. The locking makes it skip.
what do you guys think of putting some brand new stock OEM subframe bushes in, instead of even pineapples?
Aim is to get rid of the harsh clunking from the diff. Has anyone gone from stock to pineapples and noticed whether pineapples make it noticably louder clunk?
I put the alloy ones in as i thought theyd be even more effective than pineapples, which they would have to be in terms of reducing subframe movement, but honestly i dont think i couldve picked the difference seat of pants once they were changed, which is why im thinking just put stock ones in.
That's a LOT easier said than done! U've gotta melt out what's left of the squashed oem bushes, press the surrounding 'ring' out and get a new set pressed in. If u'r gonna do all that, I'd put a set of noltec subframe bushes in (not just pineapples). The noltecs will be noisier than stock tho, but probably not as loud as with pineapples.
haha yeh everyone who gets in my skyline and hasnt been in a car with a 2way before thinks my car is f**ked and gonna fall apart, but yeh mine is clunky n shuddery when making tight turns, all good fun tho
I have a 2 way nismo sss in my car and got it new.
it's in an R32 gtst with a button clutch, alloy cradle bushes and rb30det torque. it clunks like a bitch accelerating and decelerating in corners. I have tried all types of fluid and now am using syntrax.
it really is too much for the street i hate driving it when cops are around. i am going to take out the alloy bushes and see if it is any better.
I lived with it in Canberra for almost a year no probs, but in Melbourne traffic it is just too much.
do not put a 2 way in a daily driven car. I am going to pull mine out when i can be arsed and set it to 1.5 way and with less preload.
I have found friction modifier also helps to a certain extent.
mine seems to clunk less when it is cold. once it warms up it clunks like a cut bastard.
having said all this when you are actually driving the car it is a pleasure.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
