hey all i have only recently bought a turbo skyline, it has a rb25det wit forged internal, im not to sure what oil temp or pressure is normal, the oil temp usually sits at around 80-95 depending on how im driving, im goinf to be using this car for drift and just wana know what the limits should be on oil temp and is i should get an oil cooler, also another thing, it has an apexi fc and im unsure what the knock gauge means, it usualy wont go above 10, what should the knock be at? cheers
https://www.sau.com.au/forums/topic/198867-oil-temp-and-pressure/
Knock should ideally be at zero...though 10 is generally fine. <20 is ok too. Knock is bad for engines and generally indicates a bad tune or overly sensitive knock sensor, and is one of the many reasons for engine rebuilds.
Not sure what PSI oil pressure should be at.
Oil temperature is important, 85-90 is ideal. If your are taking it drifting an oil cooler may be in order but you won't know till you go.
85-90 is ideal between brackets.. if ur just cruisin around doing nothing other then that... no thrashin, then ur oil coolin system sucks balls. Introducing minimal heat into the turbo will make it go to 100 real easy. while ur drifting/thrashin the car, 80-90 is ideal.. Stays relatively "cool" enough so it doesnt thin the oil out too much.
If it strays over 110 while on the track, which will happen very quickly and easily, then pull over and let the shit cool down
I had an oil cooler on my previous RX7 and while being severly cained, on a 40deg day the oil temp never rose above 85.. awesome cooling (had water spray) but on a cold day... it would struggle to get past 60deg.
Oil pressure... around 20psi @ idle is ok.. even down to around 10ish is ok.. @ around 6000rpm ud want it be @ around 60psi (from memory)
Dude, as per your other thread, what Gary (Sydneykid) said is worth knowing.
Any track work Id suggest an oil cooler - any "row" cooler is better than no cooler.
I need to get an oil temp guage so I know whats going on.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
