just wanted to ask a question and wondering if you guys can help me out...a 32 i'm interested in has had a rb25det conversion..the current owner says you have to engineer it so if i decide to buy this 32 do i have to get it engineered? or can i just go to vic roads and change the engine number? i asked a few people and said that you wouldn't have to and can just change engine number at vic roads?
also want to know if i do have to who does it in vic? prefer western suburbs. also anyone know prices? thanks people
Yes you need an engineers.
Whoever is telling you just to change the engine numbers is stupid and will end up causing you more trouble in the long run.
You must change it legally if you want your insurance to be validated first and foremost.
On top of that the Police can defect/fine you etc, they aren't stupid. ;)
See the VicRoads link for all the approved VASS engineers, and the closest one to you.
http://www.vicroads.vic.gov.au/Home/RoadSa...ficatesVASS.htm
Prices will vary from $600-$800 as you'll need a brake test as well as conversion sign off id imagine...
being you will be very unlikely to get R32 factory brakes passed with a RB25 conversion.
You'll be required to have the R33 brakes fitted i think you might find. (bigger motor/lighter car etc etc)
Engineers the past 18months have been under a lot of pressure, and as such are very fussy, and fair enough too.
They are signing your car off as legal and wont do so if you go with a half baked conversion.
You will still need to obtain a RWC, a VASS certificate doesnt double as a RWC. The are both separate
cheers
just to add - If you have a Type - M R32 which came with 4 pot calipers you'll be able to pass the engineers with them. If not then you'll have to do the r33 brake upgrade.
i had mine done a little while back if u need any more help shoot me a pm.
good luck with it,
cheers
    • What are you planning to do specifically?  I would be very surprised if you need to learn any math for these 'few builds' you have planned for the future.
    • I transferred from full time service to Army Reserve, so I still have access, work has been super keen to get me in to work in the OPS realm, so just turning up to use the gym......and ovens, isn't causing any issues, apart from me needing to keep on telling them that I won't be doing any reserve days until I get my joint in Goulburn sorted  Basically I can now work whenever I want, for how long I want now, and it's all tax free Next time we have some fires or floods you might see me covered in mud, or cutting sick in some plant equipment cleaning up, the Reserves love getting in the news, LOL
    • Final finish outcome of 80°c was typical to the pics, I've turned the oven down to 50°c and will pick them up after the gym tomorrow  The before and after difference was amazing, the wrinkle paint has covered all of the casting marks completely It did take a couple of hours to key it all and get in all of the crevices, but, for me it was time well spent for the final outcome, but I have all the time in the world to do it at the moment  Ended up with 4 coats, each sprayed at different angles to get optimal coverage and thickness As for the fixtures and intake box thingo that hasn't made it, the supplier is apparently posting the fixtures, and, are now sending a different CAI that is in stock The replacement CAI is actually better than what I originally ordered, but will require a pod filter that locates under the front bar, still serviceable, but it basically removes the whole OEM filter box and ducts into the front bar, so filter cleaning will require ramps and the removal of some front bar undertray, not a war stopper, just some ramps and an additional 10 minutes work every few months From looking at it it is made from alloy pipe from the throttle body, through the CAI hole in the rad support, then right turning under the bar, luckily the wrinkle paint was on special and I got 2 cans for $30ish, so the alloy will get the same wrinkle treatment as the intake manifold, hopefully it turns up soon, either way, the car will be getting booked in soon, if the parts aren't here, I'll just get MX5 Mania to " make it work"
    • I'm so glad base security is so high. I see they stopped some random codger from being able to just wander in off the street... 😛   PS, intake looks good!
    • So far so good, another hour and their done
