I have started to lose compression and seriously blow some blue smoke. Looks like its time for new piston rings, which is a shame because they were only done 4 years ago.
I can buy an L28 engine on the cheap, but it is from a series one 280zx, with an N47 head and dished pistons. It has not been in a car for 3 years.
Questions:
Should I go for flat-top pistons, and if so which brand/where from?
Do I stick with my E88 head or change to the N47?
Will either head need modifications to suit flat-tops?
Would it be easier/cheaper to buy a 280zx series 2 engine that already has flat-tops and the P90 head.
Cheers,
D
https://www.sau.com.au/forums/topic/198884-l28-engine-build/
  • Replies 50
Questions:
N/A or Turbo is the end result??? as flat top pistons in an E88 or N47 will give a compression of about 10:1
E88 EFI Head is considered among those that are supposed to know as THE BEST n/a head available. N42 & P90 seem to be the choice in turbo application but with either N42, N47 they have the same sized valves and combustion chamber volume.
In my opinion this is the way to go, but I have been criticised before about this. P90 and flat top pistons give a comp of about 8.5:1 on stock bore and 8.7 at plus 1.0mm and is regarded as the best of the best in turbo heads as it was the factory choice at the end, but not always easy to find at the right price. Remember any L28 block is designed as a rear sump and will need to be modified to become a front sump engine, oil pick up etc. Drilling the front dip stick hole will block the rear oil return, but that's not a problem as you don't need it with the front sump configuration. Getting a new dipstick holder might be a problem though. I keep getting promised one from afar but nothing eventuates.
Thanks for the heads up.
To clarify I was thinking of staying N/A, and recycling my overpriced carbys and E88 head (as they have both been checked/rebuilt etc), unless there is good reason to do otherwise.
I have a mate shopping for parts in Japan as we speak, maybe I should put him on the case to search for dipstick holders. Do you know which model you need to poach it from to suit this application?
Cheers
Thanks for the tip re: the dipstick.
I bought some flat tops today - I'm getting excited! If anyone can make recommendations about which engine components to replace the existing stuff with I'd love to hear them. I'd like this engine sorted out before it goes in the car.
  • 1 month later...
Ok- I have stripped the L28 Block and had the bores and the crank polished. I have flat-tops and new rings and all the other parts I need to assemble. The N42 head is in better shape than my E88 head, so I am going to use it for that reason alone.
I am going to do a dummy assembly first (with the engine out of the car) to check that the valves clear the pistons. There are 3 pertinent questions though:
Has anyone run into major valve clearance issues before with an L28 and flat-tops?
Does anyone know off-hand what the tappet clearances for the N42 head are?
Does anyone know what color the L28 block was when new?
Any tips are appreciated. This is largely uncharted water for me, so I don't want to botch it.
Cheers
1. You should be able to judge possible interference of valves with pistons by putting a flat ruler across the face of the head with the valve fully open.
2. I'm pretty sure ALL L-series run the same tappets - .012 ex, .010 in, hot (.010 ex, .008 in, cold)
3. NFI
Thanks for the tips.
The bores didn't require a hone, they polished up very nicely. (Just as well for me, as the pistons I scored on the cheap are the standard size - not an overbore). Likewise the crank polished up well, so I'll be sticking with (new) standard-sized bearings. I forked out for a performance harmonic balancer - avid readers will recall that I split my last stock harmonic balancer into 2 pieces, ruining my week. The balancer/crank/flywheel have been balanced, and the flywheel was lightened some as well.
As well as Mr Elk's ruler method, I will be applying a dollop of blue-tac to the top of number one piston, bolting the head and timing gear on, turning the motor by hand then checking out the indentations in the blue-tac to get an idea of valve clearances. It's a bit like something out of CSI. The boys at the machine-shop will measure the remains of the blue-tac and make the call about how much, or little, clearance there is. If it's too tight I may need to invest in a thicker (Nismo do a 2mm) head gasket.
Including paint and oil, I hope to keep the whole project under a grand. It's on track so far.
Has anyone run into major valve clearance issues before with an L28 and flat-tops? .......... No! but I am using a P90 head, as my motor will be turbo.
.......... You may have to relieve the piston crowns for valve clearance.
Does anyone know off-hand what the tappet clearances for the N42 head are? .......... 0.010" for both
Does anyone know what color the L28 block was when new? .......... Blue
Including paint and oil, I hope to keep the whole project under a grand. It's on track so far. ............ how you do this?
My present cost list is over $3000.00 for my new L28ET build excluding machining.
Use this and your compression will go out the door! Probably drop to UNDER 8:1 which is N F G for your n/a motor. You want 10:1 in a good n/a engine.
Try relieving the tops of the pistons (Fly Cutting) for valve clearance IF necessary. as I said earlier.
Ok - thanks for that. I will fork out for the fly-cut if I run into trouble with valve clearences. (probably cheaper than the damn Nismo gasket anyway!)
I have mocked up the crank and number one piston, and will fit the head tonight if I get the tappet clearences spot on.
Actually, my how to build your Z engine book stresses NOT to recycle your rocker arms and lash pads when you change your cam, especially if you don't put eveything back on in the same postion it came off (eg number one exhaust rocker arm is to go back on over the number one exhaust valve - not somewhere else on the head.) When I had a close look I noticed that the rocker was not perfectly parallel to the cam. The left side of the rocker was actually touching the cam even when the cam nose was facing away from the rocker. Should I invest in new rocker arms and lash pads to try and fix this? I don't want to damage the cam.
Also I have started to go over budget. Ill tally costs after class and see what the damage is.
D
  • 3 weeks later...
Ok... I have hit a snag. The crank doesn't spin freely when I tighten the bolts for number four bearing cap (this houses the thrust bearing).
It spins fine with all the other bolts tightened, its just four that locks it up. I measured the distance between the crank and the thrust bearing and there seems to be only a tiny (0.002 inch) amount of clearance on each side.
Anyone know what I might have done wrong - the manual suggests the crank should spin freely, even with everything tightened.
Regarding costs. I have forked out for brand new gaskets, bearings, rings, shims, welsh plugs and harmonic balancer only. Everything else is a decent second-hand item that has been cleaned/honed/polished or painted. The total costs have crept over a grand including all the machining, but hopefully it should stay the right side of $1,500.
  • 5 weeks later...
Ok, finally have assembled and painted the short block and it all turns over by hand. There is buckets of valve clearance and number 4 bearing cap has been machined to let the crank turn freely. I am just waiting on new shims for the head so the tappet to cam clearances are right.
A 280zx turbo oil pump has come up on ebay. Do I want this? Obviously the car won't be turbo, but some other l28 N/A engines I know of are using this pump.
Drew,
The US spec L28ET auto oil pump is the biggest of them all, you will find H 4 on the casting, but be warned, you also may need a new drive spindle, depending on your distributor drive.
L28ET oil pumps also come as H 3 & H 3.3 the most common manual version being the H 3.3
The L20ET pump is also an H 3
Cheers, D
That's great to know - and your right, it is blax240.
I (will) have the L28ET oil pump, L28 (n42) block, L28 timing gear/cover and an L28 electronic distributor. Will the drive spindle I need have to be for an L28ET or can I get away with the non-turbo L28 drive spindle? Are they different lengths/shapes? I have never seen the L28ET drive spindle so I can't compare the two.
Cheers for you help,
Drew
It has a lot to do with the distributor drive. The turbo distributor has a spline drive, but from memory the n/a distributor is an offset cam, so you might be ok. Just do it your way and if you get stuck let me know, as I have a couple of turbo spindles.
Cheers, D
Cheers, D
Excellent - I'll give it a go then!
I finally got the call and the head is ready to pick up - just in time for the long weekend!
If you don't score the turbo pump from blax240, I have a H3.3 I might be tempted to part with, as I have an H4 & a new hi flow I bought from SWR some time ago. Send me a PM coz I might have something else that would help your n/a that I'm not to fond of advertising on here.
Cheers, D
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
