  • Replies 50
If you don't score the turbo pump from blax240, I have a H3.3 I might be tempted to part with, as I have an H4 & a new hi flow I bought from SWR some time ago. Send me a PM coz I might have something else that would help your n/a that I'm not to fond of advertising on here.
Cheers, D
Is the hi flow you got from SWR a H4 ?,
if it's a H4 then I suppose it worth the $137 they want for them,
considering that to get one from the US would most likely cost about the same.
Nigel
No it's not that I know, but Stewart Wilkins claims it's every bit as good as the H 4 pump, but it's non genuine and it's NEW!
The blax240 pump sold for about US$74.00 = about AU$80.00 plus freight, about AU$30.00, but it's a secondhand pump.
And Dan, the cam I speak of is the speedo drive, isn't it a half shaft thickness offset idea? Cam?? as opposed to the spline in L20 & 28ET???
And my new motor is coming together nicely, will post if interested later. Still waiting on a few parts to come from US of A.
Cheers, D
My current L26 came with a mystery cam - couldn't find a receipt for it. I'm going to donate it to my friends 240k project. The L28 that I am building now has been set up with a Wade cam grind 733A - cam lift 320. There was buckets of valve clearance with the mystery cam, so I'm hoping not to run into any problems with the Wade number. Maybe I'll retest to be on the safe side.
I slept through the end of Blax240's auction and lost the oil pump, so PM's away to Ghostrider.
  • 5 weeks later...
The block is 280zx, with the dipstick holder pressed into the side of the block. The sump is L24 skyline, and the oil pick up is too. The skyline sump also has a dipstick holder, so I will retain that one, and remove the redundant 280zx dipstick holder from the block.
I won't be able to work on the car for 5 weeks though. My mate is away, and the car is in pieces at his house. Bummer.
sorry 2 bust in here but sort of on the same topic.
put a 260z C "nismo"? cam into my l24et, but the cam doesnt have any oil squirters. now the cam lobes r dry, this gonna cause a problem? thought all L6 cams had the oil squirters. if not how did they get oil up 2 them?
also idle vac is now at 10 In/hg use to b 15. runs fine etc but yea that normal?
cheers...
Edited by OUTATIME
I'm about to embark on this project too.
Does anyone know where I can get 36mm exhaust valves to suit the P90 head?
I have all the trick bits, so I'm expecting some real good HP numbers when this 2818cc L20ET is finished.
Cheers, D
  • 1 month later...
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
