  • Replies 50
Heeeeyyy Dats looking flash as eh. How long before you turn the key? So tell me the secret of the shiny rocker cover and don't just say elbow gease. Your secret will be safe with me, just post it here and I promise I won't tell a soul.
The secret of the rocker cover is... er.... ebay usa actually. I polished all the other parts though, like the timing cover and manifold with a wire brush, then sandpaper then autosol.
Have turned the key and the car runs a treat. Once it's run in Ill get a pro to look over it to make sure it's correctly timed and that I haven't misseed anything.
Hey,
These twits stock the pulley,
http://www.thezstore.com/page/TZS/CTGY/PEM06
but good luck with their defective online shopping cart, or getting them to answer emails. I got lucky and found mine on ebay USA for a little less as it turns out :thumbsup:
Word of warning though - these pulleys do not quite fit onto the key on the end of your crank. You'll need to file a smidge off the sides of the key to get the pulley to slide on without breaking the pulley, the crank, the oil slinger etc.]
Cheers, d
I bought my pistons from them. Plus 1.0mm forged flat top Ross Racing Pistons for a tad under $700.00 delivered. Compared to nearly $1600 here in Oz to get them made. Had no hang ups, deal went very smoothly.
Cheers, D
Actually, I have tried ordering from them again. This time I filled out both my mailing details and the billing details (it says that this isn't necessary if they are identical) and the cart was able to process my order. I'm still dirty on them for not replying to my polite email, but there's no denying they have some great stuff for L series engines.
  • 2 months later...
Changed to an electric fan on a thermo switch and tidied the last few things over the weekend. So that wraps up the engine build... until I have enough money for triples, and a stroker crank.
Now... time to paint the body.
That looks great man, very clean and tidy.
Am so tempted to give mine a good tidy up, but my wife will do unspeakable things to me if I head down that road again :P
Quick Q's: Did you make your strut brace, if so where did you get the turn buckle/adjuster from?
Cheers Dan
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
