Hi Guys,
I've been trying to look around everywhere but can't find any info. My Mate has an r34 Gtr and we've been having a few issues witht he lcd screen and the head units...
1) First off is there a known issue with the screens displaying white lines from top to bottom? His one has two white lines, looks like a graphic issue.
2) We kinda figured out what some of the buttons do on the screen but have no idea what the cd player and dvd player buttons do at all... we keep pressing things and other things happen.... Does anyone know or have translations for these? I've been looking around the net and searching to no avail. Is there an english pdf floating around anywhere??
Thanks in advance for your help guys!!!
https://www.sau.com.au/forums/topic/198899-r34-vspec2-translations/
Hi Guys,
1) No idea.
2) Is this the unit with SAT Nav? If so, I've worked out some of the buttons. I'll take a pic and post something up over the next couple of days.
1) No idea.
Yeah its got the sat nav, we can't figure out how to get through some of the options. Also was the g-force counter an option in these? Because our one doesn't have the icon on the right for it...?
Thanks anyways mate!
If you've got access to get a pic of the dash, I could probably explain some of it. The rest may need to go into a different thread. Some of the guys who can read Japanese were really helpful.
G-Force meter is a Nismo MFD option, not on the standard MFD's.
Only thing I found useful for explaining the MFD (if it helps) is attached:
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
