Hey, i had this problem with my 32, coz i got a half cage and no back seats. Cops yellow licky'd me and told me told i needed to register it as a 2 seater. So i took it to Pits in Kelmscott, told me i COULDNT do it. Confused i called the Technical Section in Welshpool, told me it was all sweet, told me to check the National Code of practice (linked)
http://www.infrastructure.gov.au/roads/saf...n/vsb_ncop.aspx
Check the pdf file labled, LK Section to do with Seating and occupancy. basically, if you plan on PERMANENTLY removing back seats, you need to seal up any holes left by the removal of back seats, boot still needs to be seperate for cabin (ie parcel tray and metal plate need to stay in place) and then fill out a form saying you wish to register it as a 2 seater. Might need a engineer or Mech to sign sayin, yes it meets the requirements on the check list. Just read the PDF file, pretty self explanatory. All the best with that.
I ripped mine out (s15) for collie, then when I went to put them back in, I couldn't get the seatbelts to come out... Seats were in tho. Got stickered one night for bald tyres and had to go over. Rather than f**k around with the seatbelts, I figured I'd go the 2 seat option so that if I needed to pull the seats out again, I could, legally.
ALL bolts/brackets/anything else sharp/not a part of the body needs to be removed and you need something to block the boot from the cabin (I used MDF drilled into the body). I think that's to do with fumes/possibility of explosion, but I'm not sure.
My car is still rego'd for 4 seats, but have the permit for no rear seats. So in the event I want to take the whole family out, I can throw it all back together (with seatbelts) and still have 4 people in the car legally. In the event I want to go to collie and load up 10 tyres, I can rip it all apart and do that legally.
Only thing is, I think you'll find if you have the back seat in, you will need to have the seatbelts in. So even if you have the permit and get pulled over, not having seatbelts for seats is a yellow, where as if the whole lot wasn't there you'd be fine.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
