Hay guys!..
Well santa dropped off my coby extractors that we just got from the group buy!.. :)
I was thinking we could start a thread on how and what we did to install.. and to compair the increase in responce etc.
So feel free guys!.. cos Im off to buy some heat wrap..
https://www.sau.com.au/forums/topic/198936-headers-thread/
  • Replies 94
Posted Images
i just got mine today i bought them off my bros thing gtr.2nv, gts4wd keep us updated on ur heat wrap i think thats the way im goin to go i heard the hpc is to expensive
Well yeah.. thats why I went the ghetto heat wrap approach.. ;)
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3549629
nice one cris!!
hp coating is exxy. getting mine done cost me almost as much as the headers themselves.
i would suggest some form of heat insulation, as you will not be able to use the standard heat shield.
merry christmas guys and girls
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3549896
lol.. I know.. I just thought id start a thread where poeple can compair their new headers everyone will be getting from our recent group buy..
Things like.. torque.. powerband.. sound.. etc. etc. Ill be posting pics tomorow sometime when I install mine
Just a refrence thread too for the future..
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3550458
Hmmm maybe make a video/audio/picture thread?
Organise it by make and model and add tags to whom which car belongs to etc.
And get Eug to sticky it haha, so then we can have less people posting.. 'What does yours sound like?' 'Show me a video of yours' yada yada
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3551568
got me heat wrap today, my mate told me u have to replace the bolts from the old extractors, anyone know if u have to or not?
No.. yiu dont have to.. but generally on older cars they tend to seize and be quite damaged from the heat from the exhaust..
i think you should be right with a 34 though..
I will post pics of heat wrapped headers tonight/tomorow
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3553934
http://www.modyourcar.com.au/thermo-tec-ex...x-50-foot-p1328
$70 for a 1inch by 50foot roll of black exhaust wrap
seems to be a good price from what ive seen
NO NO NO!.. 1 inch is FAR too narrow!..
I baught the one inch.. took it home.. looked at the headers and the width of the wrap.. then jumped straight back into the car and swapped it for a 2 inch..
I just wanna save you time and money.. :)
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3555017
pipe clamps
wrap it at the top a bit, then clamp it tight, then continue to wrap it down the pipe - often a strategic twist means you can come back up another pipe and only have to cut once
i think it also helps to have the wrap a bit damp
on another note i'll be doing this to a set of extractors i managed to get for my excel!!! w00t :(
$120 for old, but unused, anodized mild steel 4-1 extractors....
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3558547
pipe clamps
Wrap it around itself so it secures itself down.. so you take the end.. wrap it around the pipe.. then wrap over the same peice so it secures it self down.. just make sure its nice and tight
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3558570
so its a straight forward task, the tighter you wrap it the better it will stay on.
cant wait for mine!
oh and have you got the flange welded yet? or did you wrap them first then get it welded later?
extractors for the exel, nice!
not sure if its just me but wouldnt the money be better spent if it was going towards a nice shiney skyline of your own?
or perhaps this exel has something up its sleave for the future that will blow our minds :(
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3558786
couldnt resist a deal like that....
excel hopefully departs this yr sometime for a 'line
https://www.sau.com.au/forums/topic/198936-headers-thread/#findComment-3558806
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
