All in all. It's been a bit of a mixed bag.
Installation wasn't too easy. I had to grind down the yolks (spelling? - the fatter washer/spacers between the exhaust flange and the washers) so as to accommodate for the welds on the piping as the yolks did not sit flat. I had to do this because it would of bent the studs, possibly snapped them and the headers would not of sealed properly or evenly with the head and gasket.
**note** to those who did it themselves.. I hope you guys progressively tightened the nuts and did it in proper order
Then I had to weld a flange and a connector pipe from the exhaust manifold to the cat. Simple and Cheap. But now it scrapes everywhere.
As a positive, it definately improved the engine flow! The engine is much happier now being at lower RPM and also rev's out MUCH easier..
This being said.. My exhaust note has lost alot growl.. is quiter.. and the rasp has now returned..
Thats my pros and cons..
Im in two minds about the job that coby did..
  • Replies 94
Posted Images
sorry to hear about your experience Cris. anyone else have this issue??? please let me know!! out of everyone getting headers this is the first negative report i've received. i'd like to know if this was a once off shabby weld or what.
did you use the old (stock) head studs, washers, and nuts?
not sure about your flange setup, do the headers angle down too steeply? or is the flange too big?
could possibly be your engine mounts? with having the RB25 in the R32.
in regards to the rasp/growl issue, did you previously have the stock mild steel headers? i did notice that the heavier metals in exhaust components to muffle it down a fair bit.
better yet, before you bolt the intake back together take a picture of your welds and the bolt clearance. i'll have a few words with partsco and coby.
eug
well i had mine done by kirmit
and he said that when installing mine he almost killed himself because they were a pain in the ass..
he had to replace all my top studs with bolts and put spacers in to clear the welds
he also bent the extractors up because they angled down a lot
and they weren't long enough so a connector pipe had to be welded on so they would reach the cat.
it took him, who does this sort of thing everyday, around 4 or 5 hours to do just my extractors.
so apparently not the best design
that being said they do flow a lot better and are lighter than the stock headers.
they work but its a pain to get them on apparently.
wow, coby are getting lazy. mine was in and out in 2-3 hours.
in regards to joining to the cat, remember the stock cat is much longer than aftermarket ones.
get me some pictures and i'll make sure partsco/coby knows about it. after organizing 4 group buys i would have thought they'd treat us better each time.
I have diagnosed the problem..
because this engine should fit 32's and 33's they extended the piping so as it has the extra length to fit in a 33. Put it in a 32.. and it hangs too low..
My car isn't amazingly low.. street legal 100mm all round.. but just something to be warey of..
And the grinding of the yolk was a bit of a bitch.. but nothing amazingly difficult..
All in all.. Im quite happy with it though.. its good to feel an engine breathing and farting well..
  • 4 weeks later...
Finally...gotten round to booking in to get exhuast n extractors put in...had extractors sitting arounf collecting dust so time to make good use of them =].
Hope saturday everything will be installed..
i'll keep updated and get some pics maybe vid/sound file when its done =] =]
Honestly boys and girls.. do the mods yourself..
Its all abut the late nights you spend under your car..
You learn things ten-fold!
and I garantee you they wont do as good of a job as you would..
Grinding down spaers is a biatch.. but if thats what it takes to get the job done right.. you wont care..
thats what I think so anyways.. built not baught..
i too have done something similar
i have taken my dash cluster out 6 times now and have to do it again
nothing teaches you more then taking you car apart
i painted my rocker covers on the weekend and taking my engine apart was a big learning experience
hEY got extractors and exhuast done today....hottest day ever though. didnt end up heat wrapping or coating the extractors might end up doing it later on. i asked for a xforce muffler..guy gave me some titanium exhaust looks bigga and better.so im not complaining. nice loud and throaty. Might need to drive around with the silencer on ..although its not entirely bad droaning even at cruising.
I went to Dandy Exhausts. Very friendly and did good job.
Just a note though. Usually when its a hot day like this car doesnt always perform greatly. But noticed slight increase in acceleration. Plus driving around with the air con on doesnt help i guess.
I'll try and get a vid file soon when is cool enough to be outside.
..oh yea checked the engine bay..saw the black paint starting to burn off the extractors i think.
  • 3 weeks later...
dude that looks hot what colour did u use?
cheers mate,
i went into super cheap auto and bought heat proof primer, this heat resistant metallic paint (red) they are in grey cans with shiny lids that are hard to miss and then i put on a few coats of clear :D
you have to prep the surface really well with sanding and cleaning but it comes up nice
be prepared to sacrifice an entire weekend though
hiya guys,
not been on fer a wee while as im currently in the desert doing a bit of "agressive camping" for uk plc. ive five interested parties for a group buy of these in UK, and would apreciate any and all feedback on the changes in power and torque that youve gotten since fitting. also info what systems people have fixed onto these pipes would be good. im looking at 2.5inch diameter ...as my heads been ported (rb25de) ...so any feedback would be great, good or other wise.
thanks
si
hiya guys,
thanks
si
Hey when i got my headers put in i got the whole works done =]
frm headers to exhuast everything new..
titanium exhaust
hotdog resonator
new hi flow cat
2.5 inch piping
coby headers/extractors.
since then i noticed slight increase in power not a whole lot though. mainly accel so low-mid range.
i didnt coat the headers or put heat wrap on it...i might eventually later on.
thinking about changing air panel filter and putting on a apexi pod if i can be bothered.
There was a guy named Greg who increased 25kw i believe with his exhaust/extractors/ pod i think.
Edited by blk_sz
hey guys just a few quick questions.
whats the stock piping size for stock extractors? rb25de,
also, does it matter if your extractor's outlet is 2'' or 2.5''?. i.e, whats the difference between coby d12 2'' and 2.5''?
would 2.5'' coby d12s put out more power assuming its bigger??
last thing!, how hot can the extractors get??, im buying some heat wrap but not sure which specifications i need, i.e, temperature
Edited by OoskylineoO
well basically the 2.5 inch outlet will have better flow
they dont increase your "power" but they do make the car more resposive and allows it to rev quicker
i heat wrapped mine and after i have been driving at operating temperate for say half an hour
then stop and touch the extractors, they arnt as hot as you would imagine
could leave your finger there for a second or 2
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
