I'm really wanting my car to sit a bit lower than it sits at the moment with the sydneykid road kit. I was thinking of changing the front control springs to flatout springs and lowering the rear spring retainer by one notch on the bilstein shock. At the moment, i never, ever hit the bump stops up front and very occasionally do on the rear under acceleration with 2 ppl in the back under acceleration but I can chop a bit off the bumpstop and be more careful if i lower it. I already have 2 camber kits on the rear so my rear camber will still be OK. Are there any problems I should expect doing this?
Cheers,
Brad
https://www.sau.com.au/forums/topic/198947-further-lowering-sydneykid-road-kit/
The bump stops in the kit are very compliant, so I doubt that you are not hitiing them, just not feeling it as harsh as you might expect.
Are you already on the lowest circlip grooves on the front and rear? If so, you are at the limit of the suspension geometry. Regardless of where you set the static camber, the dynamic camber change will start going positive, you will have noticeable bump steer and the extreme drive shaft angles will start to soak up even more power than they currently are.
If you avoid the rear problems, by keeping it at the same height, and simply lower the front some more, you will have a few additional issues. Firstly, increased roll oversteer as the front CoG will be lower than the rear CoG, we have found that the recommended 10 mm rake (nose down) is the best. Lower the front only and you will end up with more than the ideal rake. Plus the front centre of roll will be below ground, so the roll couple will be somewhat larger. Hence you will get more roll at the front than would otherwise be the case. This will manifest itself as excessive wieght transfer to the outside front tyre and it will understeer accordingly.
Add the major symptoms together and you will get understeer on the way into a corner, oversteer on the way out and unpredictable toe angle changes (bump steer) if you hit a bump mid corner.
So, yeh nothing to worry, about as long as you don't mind bad handling.
Cheers
Gary
Not at all. I'm on the circlip that it came with and have 3 or 4 more to go lower. I just want to lower it one more clip. Also, I'm guessing it would help that the flatout springs are stiffer than the controls which will help to not bottom out a bit.
Front: It's an S14. Mcpherson strut. Non-adjustable height.
Edited by bradsm87
SK, what was the recommended circlip groove for an r33 gtst with the Bilstein group buy suspension?
The standard one.
The 4th one (counting from the bottom).
Most importantly, the one that gives 350 mm front and 340 mm rear.
Happy New Year
Gary
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
