No, no mucking around, although to get it licensed the rego boys are going to want to see that you have updated to all the V8 gear - springs, brakes (all the brakes from master cyl to discs and callipers) diff, and....erm....thats about all I can think of. Remember that the XD did actually come with the 351 as optional (it wasn't deleted from the option list until mid XE)
The thing you have to ask yourself is, is it really worth it? The old XD-XF falcons really aren't worth a pinch of shit anymore, and its not worth pouring all your heart and soul into one unless you are looking at keeping it forever. And trust me, even with a V8 in it, unless you are drag racing it, it WILL be a dissapointment after a 200SX. Don't get me wrong, if you cut me I bleed blue ovals, but they are just a old falcon now, and they will never increase in value like the older ones did (unless it is an original ESP and you really don't want to upset the originality of one of those, and most of them had V8's in the already)
hey there,
me uncles gotta a XD falcon 6cyl the car is quite clean for its age and he wants to sell it to me and i wondering if a 351 would fit into it or is there some kinda mucking around
cheers
brakes are the same across the i6 v8 range with xd/e/f series front struts and springs are different (will need the v8 ones )
rear leafs are different rating as well you can get them reset at any decent spring works but most vehicle examination places wouldnt be able to tell the difference in rear springs
diff centre also different 8 3/4 lsd are relatively cheap from a wreckers
but your best option would be upgrading rear end to disk brake either 9 in lsd or an 8 3/4 lsd
i looked into doing this many years ago and was told that brakes and suspension was the same for 6 or 8
But this isnt the place to be asking, there are plenty of ford forums with more accurate information.
Edited by W0rp3D
yeah as has been said putting a 351 into a xd is rather easy. if it was an xf then you would be in for a bit of a shit fight. i would also agree with going for the fuel injected v8 out of a later model. rather cheap to buy and much nicer motor, or a turbo motor from an xf or even a just 4.0L 6 out of a later model falcon. as for performance, it would go ok because even though they are a massive car they are rather light (somewhere round 1300kg, depending on options). so with a decent motor they can get up and boogey. but that said it won't corner like a skyline. it will still handle like a xd falcon.
yeah buy a windsor, i build a few clevos but they are tight in the bay.... fit this to the windsor while your at it.
http://cgi.ebay.com/ebaymotors/Ford-Mustan...sspagenameZWDVW
this is my slug.
http://s188.photobucket.com/albums/z46/URA...rent=v8ltd1.flv
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
