Hi,
First this is an intermittent problem.
I only first experienced this today. I stopped at the lights and the car started idling very roughly.
I took off and it would barely accelerate, seemed to be once I got around 1,500-2,000 revs.
It's difficult to explain but it would not rev any higher than 2,000 and kind of makes a missing sound and reving up and down...
I rolled off the road, tried to rev it in neutral..still the same. I turned the car off, started it again was still the same.
I waited about 2 minutes and tried again, it worked fine this time.
I parked the car for about 1 hour, went for a drive. It was fine for about 10 minutes then started with this issue again.
This time when I pulled over..it would not rev past 1,000 even with foot to the floor.
I turned it off started again, drove to where I was going and parked for about an hour. Started up fine again, now I drove the car for about 3 hours on and off. No problems at all. After I stopped again, left it for 30 minutes. Driving again, after 15mins same issue.
This time when I let my foot off the accelerator, the car stalled. I started it again, the problem still persisted.
Turned it off for 1 minute, I drove home. around 10mins. It was fine all the way.
I've noticed when it starts doing this...on idle it will rev higher than normal and sometimes it will rev up and down on idle. Sometimes up to about 1,500 to back down to almost a stall then back up. It usually revs at about 900 when its running properly.
It's really intermittent though. I thought it might have something to do with the fuel but I've really got no idea what it could be.
Also it has another issue on idle which is extremely intermittent. It might happen once every 2 weeks.
Sometimes when I start it, it will idle abit roughly and stall right away. Sometimes this happens when I've been driving for a while and come to a stop. I was planning to get my mechanic to take a look at it on next service. I didn't worry too much because it doesn't happen often.
The thing is when it's not having the issue, it runs perfectly...
If anyone has any ideas of what possibly could be causing this, that would be great.
Thanks in advance ;)
https://www.sau.com.au/forums/topic/198969-problems-with-my-car/
There are a few things you should check,
1: AAC valve, this controls your idle when the throttle body is closed its location is on the back drivers side of the engine "Blue and Brown" plugs, i see you have an r33 so this is where u will find it. Take it off the car and clean it with carby cleaner. Do a proper job and get all of the baked in shit off.
2: Your Throttle body is full of crap, also clean that with carby cleaner.
3: Once you have done these, Disconnect your battery (If u have a stock ecu) and stand on the brake for about 1 minute reconnect the battery and go for a thrash and i mean a thrash, dont baby it or the ecu will learn a dodgy map. Your idle should return to normal.
If not let me know.
One other thing, Your TPS (Throttle Position Sensor) might be rooted, Hence the wont rev over 2k rpm. Its happend to people before.
I've checked the AFM's just now, they seem fine. No dry solder points.
I'll try checking all the hoses, bov. I hope it is something easy like this.
It's just strange though, I've read some people were having this issue when hitting a bump on the road.
But mine first happened when I was stopped at the lights.
I don't think it is the AFM's unless one of them is faulty itself. The solder points seem fine.
It's just really intermittent. I drive for 3 hours the other day with no problems. then in the last 10 minutes it occured again :D
When I pulled them out, I checked the connections. Seemed like the were connected properly.
Any other ideas?
Thanks
Edit:
I've just noticed in one of the AFM's there is alot of dirt or grease in the centre piece where the air flows through...
I couldn't see this until I put a torch on it, the other AFM is completely clean.
Would it be possible this is causing the problem?
Edited by Line
Yeah, any dirt or oil on the sensor is bad news. Get some carby cleaner or brake cleaner etc, and give the sensor a good spray and let it dry. Do you have an air filter that you oil? If so, clean it and cut down on the amount of oil you use to re-oil it.
I've just taken the pod filters out. They are HKS pod filters. They are not in good condition. I'll need to replace them.
I guess this might be why I'm having these problems.
Now to find out where I can buy them lol.
Hopefully cleaning out the AFM and replacing the filters will fix my problems.
Thanks alot for all the help :thumbsup:
I would suggest going to the bother to get specific electrical contact cleaner.
some of those other cleaners mentioned might cause problems with the plastic near the AFM's
There are some " 3a racing filters " going around that are cheap ( $20 ) but supposed to filter and flow quite well . Maybe just get 2 of those and see if the problem improves.
its not one of those HKS mushroom ones is it?
Yeah, its the dome shaped(Mushroom) pod filter.
Do you know where I can buy these 3a Racing Filters? Would normal car stores sell them? Autobarn etc?
I've been looking online, I've seen the ones I need. I know I can get them if I buy online but wondering if any local shops(Canberra) would sell what I need.
I don't know if its normal, but the filters themself look abit cheap..when I took them out. I was very careful and noticed it was starting to get a small tear on the outside. One is very bad, while the other looks like it is just starting to happen. I'd assume these have not been replaced in a while.
I'll clean the AFM sensor, replace the filters once I get them.
And the spark plugs! lol
Hopefully it fixes it :thumbsup:
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
