Do you know anything about auto leveling and washers on the front, you see I have HID's and got a yellow went to the pits and they told me HID's have to be auto lvl and washers on the front otherwise they have to be put back to stock..... does anybody know if this is true...
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3550139
Well i know that luxury cars that come out with HIDs from factory have those washers to clean the headlights, so probably is true.
Why not just replace the stock ones back and go through pits, then install the HIDs again? I did that when i got yellowed.
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3550557
i've been selling H.I.D. for few years and lots of members here know me as well.
there's no H.I.D. legal without autoleveling, self washer, and projector lense.
who ever sell h.i.d.and tell you that hid under 6000 is legal is just try to cheat you and missleading the understanding of the law.
no aftermarket hid is legal.
HOWEVER
never heard anyone got pulled over and got yellow sticker only because of the h.i.d.
also, if you hide the ballasts well, you can go over the pits with no problem, coz when they check the car is daytime and thy wouldn't tell the defference.
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3561723
Thats all well and good bankids but its on the sheet that have to remove them so now im at point now where I have to change it back over, But thankyou about the info about the auto lvl and washers at least now I know the guy wasnt full of it
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3561927
Probably a stupid question but why are hid lights illegal to install on cars that didnt come with them? If there a better light wouldnt they be better to use?
because as bankids mention your car needs to have the following...
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3562286
Because HID's are a lot brighter than standard lights and emit a different kind of light, and because of this the light is not controlled and adjusted correctly. So when somebody comes driving down the road in the oposite direction to you, they can see sweet f**k all because you've essentially got high-beams blaring into their eyes.
That's why you need the washer, projector and auto leveling because these three things stop the HID light going astray and blinding the crap out of everybody else on the road.
I'm quite interested in replacing my high beams with a cheap HID kit, becuase they're high beams so I dont really think it matters (from a moral stand point) if they are blinding and point up too hight (compared to standard beams). I know they'll still be illigal but I wont feel bad and they wont be blinding eveybody. Plus it makes my country driving that little bit more safe. :down:
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3562442
I'm quite interested in replacing my high beams with a cheap HID kit, becuase they're high beams so I dont really think it matters (from a moral stand point) if they are blinding and point up too hight (compared to standard beams). I know they'll still be illigal but I wont feel bad and they wont be blinding eveybody. Plus it makes my country driving that little bit more safe. :P
When u pick the colour for your high beam, don't use any colur over 5000k as they don't work good on high beam, i have 10000k hid kit in my high beam 8000k in foglights and 4300k in lowbeam, when i did some country road i felt the high beam doesn't really work.
also when u want to buy some cheap ones that's ok just buy from local shop who do replacement inside of australia. at least when u want your warranty u can still find them.
my 2 cents
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3566047
Thats a good idea. . putting them into the high beams. Would that work? You would be able to just flick back to low beam when on coming cars are there. I do a fair bit of country driving so some a bright light would be good to have as i dont really want to put spotties on the fromt of my supra
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3566156
only disadvantage of put hid to hi beam is when u switch to high beam it's not instantly light up, always being a flash before it lites up. so when u drive country road you gonna watch out. unless ur hi and low beam can be on at the same time..but skyline can't
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3566327
Unless you re-wire it, another mod I was considering but haven't had the chance to look into. Probably a bit beyond my electronics skill, but I have a few mates who are into that sort of thing and should be able to help me out there.
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3568147
There is a guide on how to do it somewhere here on SAU... Its quite simple from memory. Try the Tutorial section.
Edit: Here you go... It involves removing the indicator stalk and bridging the gap between two points with solder. Pictures and all, this is about as simple as automotive electronics gets! :rolleyes:
http://www.skylinesaustralia.com/forums/Du...html&st=40#
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3576265
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
