hmmm i havnet got to do it yet but im doing it when i wake up :thumbsup: haha what size are the bolts that u bought? because teh stock ones are too short? and also what MM washers were u using?
Cheers
Chi
Edited by Chi100188
"...I will however remove the rubber strip at the back and report back as to whether that + 10mm raise decreases under bonnet temps :down:"
Hmmm makes me want to try and RIP off that seal, but i dont have a proper gauge/tool to measure the engine bay temperature.
Its been done and recommended by some knowledgable cat that works in O'Connor :) There is a low pressure area at the base of the windscreen...rip out the rubber strip and i guess raising the hood will assist, just recirculate the A/C to avoid sucking fumes into the cab
Has anybody who has done this 'mod' notice their air-conditioning not working aswell or hot air entering the cabin during stop start driving?? The HVAC sucks outside air from the base of the windscreen when its not in recirc mode and by raising the bonnet wouldn't this means it's sucking hot air from the engine bay instead? i actually read up a bit on this a while ago and i think you will find no real conclusive evidence that this helps your water temps, it stuffs up the aerodynamics that is going on inside your engine bay im pretty sure by creating a high pressure system in your engine bay, this stops air from being drawn through your radiator like it was designed to do. Unless your doing static burnouts or slow speed stuff that creates alot of heat without aerodynamics coming into play i would say leave it alone, maybe in certain high mount turbo installations it may be beneficial?? Has anyone got real data on this??
Drops the engine bay temps on an R32 GTR by removing the rubber strip as evidenced by a few degrees drop in intake temp when I last measured it. The down side is fumes.
The raising of the rear of the bonnet is well documented to assist in cooling on many vehicles, I have done it to a number of cars I have owned in the past.
It doesn't fix overheating issues however and if thats the reason for doing it then it's not going to help, there is an issue with the cooling system that needs fixing.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
