hey
leaving to go to surfers paradise tomrrow and going to be up there for the new year just wondering is it a good place? does it get real packed and is there alot of idiots or is it generally a good place everyone is calm and having a good time
cheers
You'll get your usual morons trying to pick fights usually around 2am but thats the same as anywhere. It will be packed out but you will have a good time. Be sure to get a good pozzi for the fireworks. Hope weather gets better.
I will be heading to Burleigh Beach :blush:
Happy New Years :banana:
yeah its just im going there with my gf and some people have told me theres alot of idiots around there that will pick trouble , im just going to go have a good time im going to be staying in a ocean view apartment so yeah i will be able to watch the fireworks
happy new yr 2 u
cheers
Im working too at a servo near surfers. I think im getting shafted pay wise too.
Honestly surfers can be an average palce alot of the time but the more upmarket places have a good vibe going. With surfers its normally a case of you get what you pay for. Find a club offering your music style and buy tickets before you go. NYE can sell out quick and dont forget the 3am lockdown.
Yeah i'm not worried about paying for a good club the mrs wants to go to dreamworld and stuff i'm just wondering is it usually packed the lines should i purchase them before i go?
thanks
thanks
Lines at dreamworld on the Christmas holidays are so bad, everything takes 30mins to go on and the undercover waiting areas are hot and stink like BO. I'd go to wet'n'wild shorter lines, you aren't stinking hot and the rides are more fun.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
