  andz said:
got a set coming early in the NY
just wondering where i could get it fitted? or is it a DIY job?
do i need to get some kind of certicate of authenticity for my original odometer reading?
cheers,
Andy
Pretty simple diy job.
To remove from memory - 2 screws top, 2 screws bottom of the cluster, no need to remove steering wheel, remove it from the side (probably the hard part), then unhook cables. Reverse procedure to insert cluster again.
https://www.sau.com.au/forums/topic/199085-closed/#findComment-3550970
thanks ^^
sounds simple
any calibration needed? seeing that its going from 180 to 320
https://www.sau.com.au/forums/topic/199085-closed/#findComment-3551016
  Madaz said:
nice Andy finally joining the 300kph speedo club :(
im sticking to the speed limit
so far no speeding fine (yet)
  SAGTS-4 said:
if you dont mind me asking how much did you pay for it? i got a mate who wants one
just under $590 delivered
(Nengun/Performace-wise around $670 delivered)
https://www.sau.com.au/forums/topic/199085-closed/#findComment-3552559
  • 4 weeks later...
Does anyone know if it is possible to install one of these into a GT-T?
The speedo and tacho positioning is reversed of course, so that is a potential problem, depending on how the circuitry and wiring are done at the back...
Thanks for any ideas/advice people :)
https://www.sau.com.au/forums/topic/199085-closed/#findComment-3599691
