hi,
long shot but maybe someone has some new oil not used at home?
after an oil change gone horribly wrong i need approx 4 liters of 10w40 oil to suit GTST
will pay beer or cash or both as i need the car working
im in tullamarine - can come pick up if need be with another car
https://www.sau.com.au/forums/topic/199112-need-oil-in-vic-tonight-if-possible/
paul
call Harold from performancelub.com. I will PM you details, his place is in Fairfield or similar so not far from you.
Here is his website and products/prices.
http://www.performancelub.com/index.htm
He only has good oils, the Castol is both German Castol (0w30) and from the US for the 40wt. I always get redline from him. The M1 is from the US also, all are top shelf.
Everyone should be buying from him anyway cos its shit loads cheaper for the good stuff.
He runs the business fror his home and therefore is always there!
Cheers
hey all
thanks for the help i got some oil sorted -
im a stupid head and didnt realise the local servo would have some oil - shell premium 10w40 just cost me $70 though
for those who want a laugh
brought some new 10w40 turbolight 4100 and i dropped the sump bolt, get rid of the old oil, no worries
ripped off the old oil filter, got the new oil filter, rubbed some oil on the seal and put it onto the engine
little did i realise the old oil seal was still on the engine so when i fitted the new one they both clamped up real tight
it felt like it was going on normally so i thought it was fine - sump bolt back on - filled her up
gave it a crank good oil pressure around 3kgm2 and oil spewing out everywhere - doh!!!!!
so had to drain it all - didnt have a prefectly clean container so had to ditch the new oil didnt want to risk dirt etc
so drained it all out, refitted sump bolt, removed the filter, and lo- and be hold the old seal was there too - woopsies
anyway - an hour later - some frustration and swear but all good
:banana:
hey all
:banana:
hehe
nice work. DIY?
:blush:
ROFLLLL...i've did the same thing last oil change.
Stupid thing is though, i was looking at the old filter on the floor thinking "....hrrmm, that filter looks *different* than the new one, but i cant figure out why."
:thumbsup:
yeah i know i was there today when i got the first batch of oil
but by the time i had done it and failed they were closed
anyhoo all sorted - i might be intereted in that tool case you have for sale
hey paul if you wona come over and have a look at the box fell free im in melb to next ill shoot you a pm with my mob no
same goes for any one else whos intested just pm me i would like it gone by the time i leave for wagga
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
