Just a quick question here, is the am oil filter for rb25det and rb26dett the same?
I just took the car for a service at nissan service centre. They changed the am oil filter but from the packaging it says its meant for rb20det and rb26dett.Is this compatible with rb25det? After that i've noticed that the oil pressure sometimes read very low:1-2 engine dies if it falls too low. I've boiled down the problem to 2 possible cause:either the am oil i'm using(motul 4100 semi synthetic 15w50) or the oil filter as none of this has ever happened prior changing the am oil.If it is the oil filter that is causing the problem, what is the oil filter part number for rb25det?
any help would be much appareciated, thanks guys.
https://www.sau.com.au/forums/topic/199191-am-oil-filter/
