Hi all,
I decided to buy the Apexi power intake pod filter which set me back $180.00 for the complete kit which I thought was reasonable and then installed it on the weekend which was a breeze to do as most of you would already know.
What I would like to know from you other people out there is that for those of you that have fitted one of these pods, did you notice a slight decrease in power apart from the induction noise you get. I also know that your supposed to box the pod up to stop it from drawing hot air which I haven't done but is it maybe because it needs to be tuned for this type of filter?
Will it make it run richer as well?
Thanks guys,
Gianni
https://www.sau.com.au/forums/topic/19921-just-fitted-the-apexi-pod-filter/
I got an Apexi pod and it seemed to offer slightly less power than when I had my friend's borrowed HKS pod on. But that was because of all the extra hot air it sucked in (the HKS pod kind of faces forwards and suchs in more air from the front) because once I put the cold air box in, it had more power than the HKS.
$180 is a good price. I got mine from Japan for less than that, but I kind of *cough*avoided*cough* customs.
The car doesn't need to be tuned for the pod/box, and it shouldn't run any richer than normal. Not enough to require tuning anyway, but an S-AFC or the like always helps.
Hi JimX,
thanks for your info, I'm thinking of getting a Power FC down the track for extra tuning ability but money is always a problem as most of you will agree on that one!
One thing I would really like to know is having the Apexi pod on rather than the standard air box, will you gain anymore power?
I'm thinking I should have gotten a dyno done before & after to see what the results would have been!
I don't know if pods offer more power than the standard air box because mine came with a pod and no box. In theory I guess they should, they have more surface area and a better shape for the intake.
I was a bit curious myself.. and had to take off my Blitz pod for an EPA. When I put the stock air box I noticed marketed less response and total power than with my pod with same 10psi boost, although my S-AFC, etc was not tuned for the box.
...mind you this was with unknown filter, so the results could vary
Thanks to all the reply's,
I think that down the track when I decide to do a bit more tuning like boost & power fc, the pod will pay off... hopefully. I'm just deciding weather I should leave it on for now? will I be using any more fuel with it on and no S-AFC or power fc? I'm sure someone did mention that putting a pod filter on will make it run richer...
who knows?
Thanks again guys....
How would it make your car run richer? If anything I would have thought that better airflow=leaner running, but either way the AFM works out how much air is coming in and adjusts the mixture accordingly.
Well, my car has a bit of a fuel problem anyway, but after fitting the pod I lost around 20K's. 30L gets me around 230k's.
The most obvious difference is the noise factor. You can actually hear the standard bov :rolleyes:
I couldn't tell you if it has made it any faster, but it feels like it comes on boost faster. Not a huge difference but a noticeable difference.
I don't have any stats to prove, but i believe i felt a difference.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
