Apexi Boost Solenoid Question
ok here is the boost solenoid picture...the com goes to the wastegate....what about the other hose???? i tried to remove the other hose, should i feel air vaccum??or air pressure coming out?? when the engine is at idle?? i don't have any air coming or vaccum when i tried to remove it....help thnx
com - is wastegate
no - goes to turbo, or if ya have an externally wastegated turbo with no fitting, goes to a boost pressure source ( before the throttle body of butterfly)
i have just changed to an externally wastegated turbo so i have to change mine around and put another fitting on my boost solenoid.
COM needs to goto the wastegate
PORT needs to goto the intercooler pipe work or vacuum line from the manifold
if you dont connect PORT the car is running unlimited boost and you'll do damange if you load the car up and hit boost
could it be possible my boost solenoid is not working?? i read from other sites that the boost solenoid will click and sound when hitting the boost.....i can't hear from mine....i tried lowering the boost settings...last night i tried...still 1.6 readings from m apexi avcr on the full boost....help guys...
dont you have off A and B settings for boost.
you should only hear the clicking if your boost solenoid is sitting on something metal. As the clicking sound is the solenoid hitting it.
Mines mounted to my strut tower at the moment, but i am moving it.
What hoses have you got connected to where?
on the boost solenoid there is 3 ports, with the port NC propbably doesnt have a fitting.
Com goes to your wastegate
No goes to a boost pressure source only
Your blow-off valve should be connected to a vacuum/pressure source (your inlet manifold)
then a hose coming from your inlet manifold to your pressure sensor.
There probably wont be any pressure coming from your vacuum/pressure hoses at idle ( not sure)
And you will only hear the clicking sound from your boost solenoid (if hitting against metal) when your under boost. You wont hear it at idle.
yes i have settings A and B, i set it to A, and 20% duty and still the boost hits 1.6, what could be the reason?? maybe my solenoid is not working??can we check in the avcr if the solenoid is getting a power source????
com goes to wastegate is correct...
but the port...i have 2 hoses coming below the intake...one hose with the yellow strip which is condemned with bolt and clip, and the other is the one connected to the port of the solenoid... i can't hear my solenoid clicking,,even at boost...my solenoid is also same mounted near the strut bar..
i remember before when i was not using my car for a long time, and i tried switch the key to on, i would hear the clicking sound, like fuel pump clicking, i think that was the solenoid click, i wonder, just for that moment, and after that, i can't hear it anymore, could it be the power source of the solenoid lost contact???
Edited by andy95'R33GTR
Hey i have ran into some problems with the install of vacuum lines ( i think) for my avcr boost solenoid.
I am aware com goes to wastegate, BUT the problem is that i have two ports on the 45mm turbosmart wastegate.
And also NO goes to boost pressure source (intercooler pipe before throttlebody)
My setup at the moment is all farked up.
COM is going to the intercooler piping before throttle body
NC is going to Top port of 45mm ext wastegate
NO is going to bottom port of 45mm ext wastegate
Pressure sensor has hose going to inlet manifold
Bov has hose going to inlet manifold
Should i have
COM going to port 1 of wastegate
NO to intercooler piping
NC should go to bottom port of wastegate????
And leave pressure sensor and bov as they are.
 Share
    • Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
    • Granted, which is a solid reason why I don't have one. My floorstanders are only -2 dB at 22 Hz.  So they're still working down to <20 Hz. Which is no doubt part of the reason why my receiver shits the bed! That Tonewinner would be about double the cost though, so it's not apples and apples. There aren't many AU$1300 subs (that you can buy prebuilt, I'm ignoring what can be achieved by DIYing) that compete.
    • -6dB at 22Hz isn't that great, watch the data from the D6000 from REW
    • I'll just leave this here. https://www.adelaidespeakers.com/subwoofers.html TL loading, big power. They sound awesome. This is what I would buy if I was going to try to take the bass away from my floorstanders. Just go with the 12".
    • I'll snap up some photos when I'm back home, in the office today meeting my "in the office" quota. Have 2x Teams calls scheduled in, office culture they reckon.   I've never owned a proper off the shelf sub, I've always made or modified broken ones with Jaycar plate amps and/or car subwoofer drivers. The current (and broken) subwoofer has a proper home driver in it, Dayton driver, thos one https://www.daytonaudio.com/product/118/rss265hf-4-10-reference-hf-subwoofer-4-ohm FS of 25Hz, which is low but not low enough. Yeah, I think they were brought out to the market to compete with SVS. I would love a SVS PB-3000 but they're not cheap, especially after their price hike. From reviews online, it does look like the Tonewinner D6000 would destroy and with good amount of money saved too.
