All items were purchased for an R34 GT-T.
Power FC with Hand Controller, New $1500 SOLD
Nismo 480cc Injectors, were installed on rail but never had fuel pass through them, $600 SOLD
Z32 Air Flow Meter with Tomei plug, New $300 SOLD
Tein Super Street Coilovers, used for 5,000kms $1200
Nismo matching 300km cluster and centre console gauges $680 SOLD
Greddy/ Trust BOV, used to suit RB25 $250
Blitz 80mm Stainless Steel front pipe, used $250
Nismo G-Max twin plate clutch (red cover) nearly new, was for a couple of hundred kms. $1000
I will post pictures soon. Please PM if your interested in anything.
Pick up in Melbourne preffered.
Edited by Blitz_boy
https://www.sau.com.au/forums/topic/199245-r34-performance-gear-for-sale/
  • Replies 49
Here are the pics of the cluster and centre gauges. This is a pic of the bov that I found on the net, I can take an actual pic tonight.
Actually the pic of the cluster is corrupt and won't load, I'll take another tonight. You can see part of it in the back ground though.
Cheez, I'll PM you.
Edited by Blitz_boy
if you open up the picture of the 3 gauges you can see it in the back ground. it's wrapped up in a lot of plastic so i cant be bothered uwrapping it at the moment(too hot in the garage)
Here's a pic from the net
they have been used, but are in perfect condition. there is no damage or marks on them. the kms are unknown, but judging by the condition of the meters they will be low.
I'll take some pics tonight if you like and I'll take it apart and get some pics of the plates.
Your welcome to make an offer.
Here's a pic of one of the coil overs.
Edited by Blitz_boy
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
