i have a set of tein coils in my r33 gtst but they need reconditioning desperately i live in SA and not to sure where the best place to repair them to tilbrooks maybe??? and iv been meaning to bye some cross member bushes and just wondering if its better to go metal or a harder rubber bush
the ride would probably be too harsh to use metal bushes if your car is street driven. stick with oem or urethane. with urethane the ride will feel firmer but they wont last as long as oem.
ok then iv always wondered what would be the better urethane it is then would you have any in stock mate ......i just need to rebuild my shocks now just dont know wear to get them done to be honest im not really impressed with my teins but theyv been buggerd since i bought them so hmmmm cheers mate
Fulcrum suspension will be able to do the rebuilts for you . When i did it it cost me A$160/ shock. Depending what was wrong with them too. If only general valve replacements, seals it should be that price. Which Tein coilovers did you have? Speak with Graham at the workshop at fulrum suspension. Tell him i sent you and he will look after you.
yudy
yudy
sweet bro cheers for the hand out im not curtain what teins they are there damper and hight adjustable with a solid metal pillow mount which are noisy as hell and iv noticed in the last couple days the shocks just arnt doing there job anymore my front bars hittn the bloody road cheers mate
yea give them a call in their marooka's office and speak with graham in the workshop. They will include the revalve suited to the oz roads too. It will take about 1 week counting from the day you sent it and get it back.
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
