If they bolt right on, you'll probably need the 4 door bootlid as well. The edge tapers at an angle to match the light, where the 2 door one has a curved corner.
can anyone comfirm this?? if they bolt straight on and only need 4 door bootlid, i wouldn't mind to do this also .. like 4 door rear lights tho
cheers
You're going to need the rear bar as well.
From what I can see, I don't think they'll be a straight swap over. The part where the indicator is on the sedan's, the lights are more curved compared to the coupes.
My answer would be that it's not a straight swap over, but then it doesn't hurt to try it for yourself.
its a straight fit with some minor modifications (well it is when changing from 4dr lights to 2dr lights)
from 4dr to 2dr you will need:
2dr bootlid
rear bar
both taillights
to make the taillights fit, you gotta cut away abit of the metal where it slots in to make it sit neatly, at the bottom of the boot, you will need to weld a 5mm metal strip on to make the gap as small as possible like as if it was an original 2dr rear. you can get away without welding the metal strip on but the gap from the rear boot > rear bar (above where it says skyline) will be like 2cm or a bit more.
i assume it would be the same when going from 2dr lights to 4dr except for the welding of the metal strip and cutting away some metal to fit the taillights.
if anyone wants to do it, im willing to be up for a swap (ive got a 4dr) preferbly a silver skyline :D
i like the 2dr lights better, much more agressive and sexy looking
Edited by whyte
[QUO]its a straight fit with some minor modifications (well it is when changing from 4dr lights to 2dr lights)
2dr bootlid
rear bar
both taillights
i like the 2dr lights better, much more agressive and sexy looking[QUO/]
have you found a thread, going through this in more depth or have you done it yourself? because i agree with you on the 2 door lights looking tougher and much sexier :thumbsup: and i have been looking for a decent thread or some kind of write-up about how to convert to the 2 door lights on a 4 door. like this :D
Only decent pic i could find, was from driftfest.
Edited by Greasy
Not trying to sound rude to you all, but all of you guys are wrong.
I personally have converted a sedan to coupe tail lights (see pic)
None of the parts are interchangable. The coupe boot lids are wider. And the coupe tail lights have a bigger (note: much bigger) bulb holders.
Bumpers do not fit as well, you gotta redrill everything
Edited by Chang
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
