Hey guys,
I have a rb20det gts-4 and have recently being using two drive for well.....advanced circular movement. I have recently developed a repeative knocking between 3500 and 4500 rpm in or out of gear. I was wondering if it is the flywheel or maybe something internal with the engine but she revs fine... feels normal.
any help would be awesome
https://www.sau.com.au/forums/topic/199276-knocking-at-3500-rpm-to-4500-rpm/
oh well $500 for a new one and off you go again. make sure your fuel pump and injectors are in good condition. not sure why it is showing knock at idle though...do you mean you can hear it?
