so it should be safe to run my engine and cams in at the same time?.....i might have over thought this issue.... :D
i just thought that sitting @ 1800 revs for a new engine would not be good for the rings thats all.....
So i should install them and run is as usual?
cheers in advance
used auto trans fluid... :D then wd-40 (inox) .... engine is not finished yet..... will need to sort out some underlyng issues yet....
so uras.... in you professional opinion....
safe to build engine with the cams and run the whole thing in as normal....?
thanks again for fast response......
Edited by new blood
done it on every engine i build.. yes as these are mild cams.
On big v8's i tend to fit soft springs then fit the hard springs once the engine has done about an hour or two of running, but i still run in the cam the same time as the rest.
So Uras ..... how should i be running in my package?
i was under the impression that if i put a constant rev on a new motor that there would be minimal load on the rings.... i have heard that letting idle is bad for a new motor.... wouldnt holding constant revs-speed be the same?
This is where i am getting lost.....
Cheers
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
