So i've been seeing people saying that SAFC will fixc the coil pack problem. Is this correct? If so, Power FC will do the same but more right?
If the sparks are leaking out of your HT ignition cct it is only going to get worse. Coilpaks & all types of insulation for that matter, age & eventually develop miniscule cracks (leakage paths) sparks burn, make/follow carbon tracks, line of least electrical resistance. Answer = Splitfire or in any event replace offending coilpaks with known good items.
Cheers GW
So i've been seeing people saying that SAFC will fix the coil pack arcing problem. Is this correct? If so, Power FC will do the same but more right?
no, niether is at all true. search.
arcing of the coil packs is due tothe resistence inthe electrical path being greater than an alternative route for the charge to escape from ..so the "spark" side steps the plug and either wholey or partially earths onthe engine head. this results in a weak spark at the plug and thus missfires. when hot (eg under load at high revs and when engine up to temp) this resistance increases so therefore the missfire ets worse.
as the other guys have said only option is to repair the brake in the circut. this can only be done by replacing the coilpack with known good ones.
as this aint cheap first check youre running correct plugs and that the afm is ok and air filter clean ...(carb cleaner)
im buying spitfires next week. as my coilpacks just died.
siliconing the coil packs can't fix them then?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
