Hi,
Just wondering if anyone knows of a place I can buy the HKS pod filter replacement?
I just need the foam/filter inside.
I know I can order these online or get them from ebay. But is there a place in Canberra that sells them?
Or some kind of equivalent I could use?
Thanks :thumbsup:
https://www.sau.com.au/forums/topic/199348-hks-pod-filter-replacements/
Yeah it stuffed alright lol.
I've actually had problems with my AFM because of this.
When I took it out I noticed it is tearing on the outside. It must have been in there for a while :thumbsup:
I'll pick one up from Trojan tomorrow hopefully.
Thanks for the help
Hope I'm not too late;
You need to buy the dry triple layer element. The twin/dual layer units are an oil/foam setup and can contaminate your afm [which you can clean with carb cleaner etc]. The triple layer units are dry and you will not have this problem. Advan in Sydney have them - they are light blue units [dual layer are usually purple or green].
Hmm...I've already ordered some from Trojan. I don't know if they are dual or triple layers...
I need 150mm filters, they only had 200mm. Which were the green ones; I will assume this means I will get the same ones but in 150mm. Oh well; I'll have to ask them about the triple layer filters.
Thanks for the help :D
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
