just finished installing a cooling pro fmic on a 95 r33, there is no nipple in the cooling pipes, what do i do with that line now? the kit included a t piece, and ive read in other installation guides in here what you do, but i dont know what the appreviations mean, or where what is (very new to diy and skylines)
"then had to plumb in the intercooler line.. ther is no nipple so i cut the vac line from TB and inserted a HKS T piece (HKS POWAH AND SPORTS)." <----
thats the line im left over with right? if so how do u explain that to some one who.. well doens't know what it means!
sorry for the slowness
thanks for the help!
take a look at this pic.
http://www.skylinesaustralia.com/forums/in...t&id=126534
thats where i have mine connected. i went to repco (or most car shops should have them) and bought a screwin brass nipple. took the cooler pipe off and drilled and tapped a thread into it. then used som,e of that white plumber tape too seal it off so it didnt leak. you could also weld around it but mine didnt leak so i didnt bother.
search nipple there should be heaps of info on it
goodluck
steve!
i just installed my intercooler aswell and put a nipple after the cooler next to the head but the boost went from 6psi to 9-10psi without touching anything else. is that meant to do that??
Also i had a bov that i took off, what do i do with the line that was going to that,block it off??
You need to put the nipple after the turbo but before the intercooler
Yes - block it off. (or run the line to your new BOV
a mate of mine told me instead of putting a new nipple on the pipe u could put the line somewhere else near the intake plenum?? has anyone elseheard of this? if so where would it go??
  • 1 month later...
not needed on an RB20.
RB20 turbo has the nipple on the front of the turbo (compressor housing).
see the vacuum line that goes from the wastegate actuator (the circle thing to the right hand side of the turbo entry) to the compressor cover.
RB20's don't use a boost controller valve to control boost.
the spring that is in that wastegate actuator is made to keep the waste gate closed for long enough to flow 10psi of air through. then it opens.
The RB25 turbo has a standard wastegate actuator spring of 5psi.
so they use an electronic valve to increase this to 7psi after 4500rpm or something.
so the vacuum line an RB25 goes from the turbo wastegate actuator, to the electronic controler (attached to the suspension tower right in front of the power steering canister, has a blue vacuum line going to it)
from there, in a stock RB25, it goes to a nipple on the pipe that goes from the turbo to the intercooler.
long story with pictures short...
RB20 doesn't need nipple..
Edited by GTST
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
