Hey guys im new here hows it going?
Anyways im about to start progress on turboing my VS GTS (355ci forged bottom end/heads/custom roller cam etc) and i was looking into running a single GT42R or a slightly smaller Precision PT74 but im almost thinking twins could be a good option.
Would you guys think a pair of gt3082r's with a .68rear and the T3 style 2.5inch exhaust would be a good choice on a 5.8ltr V8??
Im looking at around 600rwhp on about 14psi with spooling starting around 2000rpm and full boost hopefully by around the 3-3500rpm mark,will these babies do the job??
Thanks in advance Nick
355 is a stroker to 5.7ltr i believe
383 is 6.3ltr?
correct me if im wrong, been MANY years since my v8 days died off :thumbsup:
either way, VERY hard questions to answer when not many would have any experience, i certainly have no idea :D
not trying to be rude, but wouldn't it make more sense to ask the guys on the ls1 forum?????????? :thumbsup:
http://www.ls1.com.au/
Yeah thats an LS1 forum i have a Holden 5.7ltr stroker,besides i thought you guys would have more of an idea on Turbo's being a skyline forum and all :D
383 is 6.3ltr?
correct me if im wrong, been MANY years since my v8 days died off :D
either way, VERY hard questions to answer when not many would have any experience, i certainly have no idea :P
Nah its definately a 5.8ltr it was a 5.7ltr or (349.8ci) when it was a virgin bore but after the 30thou bore during the rebuild the cubic capacity increased to 355ci and 5.8ltrs :thumbsup:
383 is 6.3ltr?
multiply by 16.38 to get the capacity in cc's (i.e 5814cc)- so 5.8 is right
The twin setup would be the best option- saves having to run a set of exhaust pipes all the way from the other side of the engine, with the backpressure differences, heat, and associated headaches that that causes. The 0.68 ones should work well. It will need to be intercooled to achieve that rwkw figure, obviously
try this reading some info on this thread:
http://www.skylinesaustralia.com/forums/Ga...al-t134033.html
and this:
http://www.skylinesaustralia.com/forums/Gt...et-t169915.html
thing is most of us use a single 3082R on our engines, usually an RB20 or RB25 (2.0L and 2.5L respectively). What you're suggesting is using two of them on an engine with a displacement more than twice that. Now, turbo's are spooled by exhaust gasses, so assuming your engine burns twice the amount of fuel as ours, it'd make twice the amount of exhaust, which means it should spool two of those about the same as one of those turbo's on a skyline. Its only my guesstimation though. You'd really have to ask someone who works with turbo V8's for a definitive answer. I'd look towards forums in the US, specifically turbo corvette forums.
the twin setup would be the best option- saves having to run a set of pipes all the way from the other side of the engine, with the backpressure differences that that causes. the .63 ones should work well. is it going to be intercooled?
Yeah mate its got a 600x300x75 front mount already from my Vortech blower set up i sold off,would the .63's be o.k or a little restrictive on the 5.8ltr? Maybe a .82 or similar rear?
it's not quite that simple- essentially having 4 cylinders of "2.9L" worth of displacement per turbo would spool them quicker than a 2.9L RB feeding into the one of the same turbos used as a single- the reason for this is that turbos spool quicker when supplied with low frequency pulses from large cylinders
depends on the trim specs of the compressor and exhaust turbines, and the A/R of the compressor housing
i'd be looking to get turbos that can flow enough air in a twinned application to make at least 850 or-so-hp at the boost you want to run to ensure you can get the 600rwhp ur after
edit: you'll prolly want turbos that can make about 450hp each
complete waste of time
full boost by 3500 is doable on an engine that size
Yep agree with that
There are few lads up here and in Townsville that have the twin turbo set-ups on their V8's... There is also a wee Lexus IS200 with a twin turbo V8 in it :thumbsup:
Try checking out qldstreetscene.com
Those Turbos will do what you want.The big problem you will face is head gaskets as the Old plastics only have 4 head studs per cylinder and need all the help you can give them,1/2 head studs,Good gaskets etc etc. If its not to l;ate maybe look at a Chev as they have many more studs and dont try lift the heads of.The other problem has been finding drivelines that can live with the torque.
speak to capa or apss (air power systems) and get a twin turbo kit
its the easiest way to turbo a v8 with re-doing bucketloads of crap
a twin gt28ish would be plently enough for a good chunk of 500rhwp id expect
If you can't make 600hp with almost 6 lts without a turbo there is something wrong .
Most stock engines make 100 hp per lt these days without a turbo and I can think of a few that make close to 100 kw per lt .
Get rid of the old pushrod donk and buy a proper engine, with the aid of a turbo you only need half the displacement to make your 600 hp.
