Hey guys I’m sitting at home with nothing to do and my mind has started to wonder.
I thought it would be cool to mount a 12" sub on each side of the rear seat just under the rear side windows.
Has this ever been done before?
Correct me if I’m wrong but I was thinking
1. It would look really cool! :)
2. You wouldn’t get boot rattle because they not in the boot!
3. The bass does not have to work its way from the boot into the car so would seem louder, with better response!
4. And you would still have a full size boot with jack tire, etc.
Please tell me your thoughts and any experiences you might have had with this.
Cheers!
Diagram added!
Edited by sickr33
https://www.sau.com.au/forums/topic/199437-2-12-subs-in-back-seats/
Not sure how it would work. Correct me if i am wrong but dont subs work better when they are in the boot because of the sound vibration and such? Probably has been done. Ive seen subs in back seats before on silvias
If you turn the backseat into a sub enclosure, you then have to re-register your car as a 2 seater to keep it legal...
But having re-read what you just said, you won't fit 2 12 inch subs there... not comfortably...
nar i prob didn’t explain it very well i plan on keeping the back seats and have a 12"sub on each side facing the centre of the seat so they are just in the plastic side panels of the car on each side of the back seat where you currently just have fabric covering the plastic
just a quick drawing in paint, gives you the idea!
it would take a fair bit of costom work but what you think?
Wouldn't sound good as the enclosure will be too small. subs cannot be mounted like a speaker can..they need a enclosure of some sort or else get a free-air sub which sound terrible.
Stick with the subs in the boot will sound 10 times better.
JBL and Pioneer both do an 8" 2 or 3 way speaker. One of these in either side off a small two channel will give you heaps of sound, and iff you properly run sound deadener and a diffuser behind ityou will get a fair amount of bass too. No replacement for subs, but do sound nice.
itll be shyte.
those 8" coaxs are crap.
you wont get bass becuase there isnt an enclousre behind it...
what people need to understand, is that to get any sort of bass out of a speaker, some sort of enclosure is needed. this seperates the front wave from the rear wave, and therefore stops cancellation.
this is why we sound deaden, and seal doors, because it creates an enclosure....
itll be shyte.
couldn't you deaden and enclose that area?
from what i can remember when i stripped my 33, behind the 2 side panels was a large opening, which would probably create a decent sub enclosure...
i could be completely wrong however, i spent way too much time ripping every little piece out of it, that i'm trying to remove it from my memory. :P
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
