Hiya,
Catch can i fabbed today.
3 inch tube split in 2 halves, then adding 80mm flat section to expand the volume and allow for weld on fittings for the hoses.
Has a hole in the base to allow for drain back into the sump.
Has internal baffle to for oil mist to collect on inner baffle, didnt use the metal scourer stuff in the stocking as the oil drains back into the sump so if anything would happen to the stocking or scourer it would end up in the sump..
here are a few pics of it so far, its blasted ready for the powdercoating
yet to do :
Weld on fittings for breather lines and drain back
Powder coat it
https://www.sau.com.au/forums/topic/199467-todays-catch-can/
  **JaR** said:
nice work mate, cant wait to see it finished...
I just want you to make me a copy of all of this stuff your fabbing!!
haha soon soon, i havent touched a welder in a few months, since the one i was using went back to its owner :)
this particular catch can has given me some ideas on the internal workings of the washer bottle catch can in one. so hopefully i can get one of those working soon.
hehe funny you mention the washer bottle/catch can combo...been wanting 1 of those for a long time now...
here's some pics of 1 if you need any ideas
I'd definitely be interested in one of those if you got around to making 1 :devil:
Edited by **JaR**
AHAH!!!
the hardest part of it was seperating the 2 parts, now on theirs they make 2 cans and then weld them together ..
that should make it easier, just uses more material.
Cheers for that JAR
  NXTIME said:
Dont forget that in a road car the catch can cannot vent into atmosphere, hence no filter at the top.
yep thats right Charlie.
1 in - 1 out and the drain.
The Rips style would be a little messy to plumb back, but not impossible
Edit : that R33 pictured is setup wrong all together :D - kinda defeating the purpose
last pic, rocker cover still connected to the intake pipe.
lets it draw air from the filter on the catch can, plus would let oil mist go that way as that would be the easiest path for it - rather than going through the catch can first
yeh i noticed that too, if that pipe to the intake is blocked it would be okay yeh?
yep, that little one that loops over
still lets some air into the plenum if you leave the pcv open though- only on idle though
Edit : that R33 pictured is setup wrong all together :blink: - kinda defeating the purpose
Actually that pipe is a bit of a trick lol, i had nothing to block up that breather with so left the standard pipe that normally goes to the intake pipe on but blocked up the end of it (the hole in the intake pipe was blocked up aswell ofcourse), i have since got a rubber cap to block off that breather.
Thats my car by the way :), basically my setup is just the two breather pipes coming off the cam covers going into the RIPS catchcan, everything else was blocked off, my setup is illegal in aussie from what ive read but you could always just weld another fitting onto the catchcan and run a hose with a pcv/one way valve back to the intake manifold to make it legal over there, would be easy enough.
You can see in these pics how that breather was blocked off
Edited by nizmo_freek
  Craved said:
ahh yes
tricky tricky :blink:
few little extra additions in there now too - nice
hehe, cheers :), should have another new addition in there soon, ive got a hks 3037 pro s turbo kit on its way from japan :D
    • Thanks heaps Duncan and GTSBoy. I'll get my old man to sit in the driver's seat and turn it on and off while I test with the meter. Or maybe other way round, depending on whether he remembers where his glasses got to
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
